Page 99 of 135 FirstFirst ... 4989979899100101109 ... LastLast
Results 981 to 990 of 1341
Thread: CoopKill's Mistress Makeover Thread [Pic Heavy]
  1. #981
    Looks like I will be taking them into the shop that assembled the rotating assembly. I want to see what he has to say about them. That coating cost me $250.
  2. #982
    Oh, is that the WPC stuff?
  3. #983
    Similar, Micro blue. Link in the first post. And it was just under 200 according to the receipt.
  4. #984
    Feb 2011
    Scottsbluff, NE
    The front one is installed between the front valve cover and the lower intake manifold and the rear one is installed between the rear valve cover and the pre-turbo intake splitter. My main problem was that the stock PCV valve has been replaced with a straight through barb so without the rear installed I had a major vacuum leak that was being sucked into the lower manifold from the valve cover. With the rear installed it sealed that leak so the crankcase is now under vacuum at idle. I could have possibly put a working stock PCV valve back in.
    1995 Dodge Stealth R/T Turbo
  5. #985
    August 2010
    Chicago
    Oh id definitely like to see more on this...subscribed x2
    Id say yours look like #16, not 12
  6. #986
    I haven't seen a lot of super low mile bearings because I have never tore down an engine that new, but I don't like how it looks like the crank has contacted the bearing surfaces. I especially don't like:
    because the crankshaft is not contacting the bearing evenly.
    IIRC my rod bearings in my 95,000 mile motor did not show that type of polishing and in generally looked better than yours when I changed them (before it blew up later)
    I also don't like the weird appearance of the bolt holes on the upper right part of the girdle there. Are they dirty?
  7. #987
    Id say yours look like #15, not 12
    it looks like #16 to me
  8. #988
    I agree with this.
    At a certain point, they all start looking the same to me. Lol.
    One of the causes on #16 is insufficient prime of the oil system. Did you see pressure build on the gauge before you started it?
  9. #989
    The stuff in around the bolt holes looks to be a grey anti-seize, or something. All the threads were covered with it when removed. I will get pics tonight.
    Other than the front bearing uneven wear, does it look like no assembly lube was used, or could flooding the cylinders while priming caused this?
  10. #990
    August 2010
    Chicago
    woops...I meant 16..
