Page 49 of 135 FirstFirst ... 3947484950515999 ... LastLast
Results 481 to 490 of 1341
  1. #481
    Well brutal mission over. No drink, no eat all day.
    Fuel line all in place, and secure.
    Meth tank needed a mount made. All lines ran. Need to find a location for the controller, and wire it up.
    She is about ready to fire. Need to run vac lines, get new battery terminal, and do all the ecu crap.
    Sent from the Man Cave!
  2. #482
    Delaware
    Bottom of the fuse box is a good spot for the controller. Little difficult to tweak, but once its set, its not like you're gonna be messing with it.
    Jason
  3. #483
    The ignition amp is there.
  4. #484
    Sep 2012
    Decatur, TN
    Could you maybe squeeze it under the battery tray?
  5. #485
    Man vs 3/S verified
    Kingston, WA
    Why would you not put it in the cabin? You have an entirely new setup and will be doing a lot of tuning.
    Sent from my SCH-I535 using Tapatalk 4 Beta
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  6. #486
    JNS Engineering verified
    San Jose, CA
    Firewall grommet = high traffic zone ??
  7. #487
    Jim is right. Firewall grommet is a full on traffic jam. There are 5 wires that would need to exit to the bay. I still have to run an EGT wire through there. It will fit behind the passenger headlight, but I worry about water there.
    Speaking of gauges, the factory clip I epoxied to the Cianci pod did not hold up. Will need to find another solution for that. Might need to glass it in.
  8. #488
    Sep 2012
    Decatur, TN
    Drilling another hole and adding a grommet would be easy..If you hadn't already reinstalled the motor. :P
    Fiberglassing probably is your best bet for the pod..I have debated about trying to find some alternative clip system. Considering something like Mitsubishi Retaining Clip 14mm Hd Dia. 11mm Lgth And then just fiberglassing/reupholstering over the top of it on the outside so that it's not visible. Not sure it'd be a much better solution though.
  9. #489
    Man vs 3/S verified
    Kingston, WA
    https://www.pegasusautoracing.com/pr...oduct=4336-001
    Could put one of those or something similar to left of passenger footwell ez enough.
    Anywhere where feet won't be going.
  10. #490
    That looks nicer than the grommets I have. I may put another hole in, but still want the controller in the bay. There is enough stuff in the cabin now.
