Page 101 of 135 FirstFirst ... 519199100101102103111 ... LastLast
Results 1,001 to 1,010 of 1341
  1. #1001
    Are you using aftermarket main/rod bolts? The "anti-seize" you are referring to is probably moly lube.
  2. #1002
    OEM on both
  3. #1003
    One fix at a time verified
    Kansas
    My local machine shop used that grey moly lube to torque down the main girdle bolts. They do it all the time on domestics and it has been around forever. I prefer to use oil on the bolts. There's not that much of a difference between the torque values unless you do it dry.
  4. #1004
    Well I was hoping for the best but......damn
    August 2010
    Chicago
    Hmm..I wonder whats the cause of the thrust washer wear...
    The news isn't too bad it seems...mostly related to the tune at this point. I think you will be up in no time...
  6. #1006
    I need to check the crank in that area to see if there is something sticking out catching it. Weird spot for that...
  7. #1007
    Jun 2013
    Kansas
    damn coop, ive been watching this thread for a while. gotta say you are having some bad luck!
    such an odd area to be worn so much, while the rest of the surface looks great.
  8. #1008
    Feb 2011
    Scottsbluff, NE
    Good luck man, I hope Ray gives my motor a clean bill of health. I may have him take the pan off and check just so I can be sure as I'm terrified there is something I should have done that I didn't know about LOL
    1995 Dodge Stealth R/T Turbo
  9. #1009
    It seems all the bad luck comes down to the injector offsets. Now for the damage it caused...
    Sent from the Man Cave!
    *\( ^o^ )/*
  10. #1010
    *\( ^o^ )/*
    ????? I must have missed that part.
