Page 1 of 135 1231151101 ... LastLast
Results 1 to 10 of 1341
    So I finally got around to posting a thread for this 2 years of collecting parts build of mine.
    Goal? I really don't have a specific goal etched in stone. I always kept the theme of wanting a car that I can take to the track, autox, or just play watch my taillights on the street.
    I was on a straight path to the DR750 land when MTC contacted me to beta test the Devastators. I was a clutch, meth kit, and head rebuild away form the dyno. Then life gave me a reminder that it's a bitch. My work truck (dodge ram) destroyed everything in the drive train. Rear diff, transfer case, transmission, and a complete front end rebuild for it puts me here 8 months after this build should have been done. My apologies go out to Dan @ MTC.
    On to the parts list.
    * Freshened block
    . - Clevite bearing all coated with Micro Blue Racing
    . - Total Seal Gap-less Top Rings
    . - Polished crank, and honed cylinders
    * Head rebuild (no porting yet)
    * MTC Devastators
    * Drweldin's Upgraded Wastegates
    * GCTech SS headers front, rear, and O2. coated with Cerakote
    * HKS Twin Power DLI w/ new oem coils
    * ETS front mount
    * dbest671 rebuilt/polished TB
    * Snow Performance stage 2 Meth kit (direct port injected)
    * 3sx Poly mounts
    * M2 Turbo back exhaust
    * Ray's bell housing brace
    * Big bore lifters
    * Wally 400
    * GZP Fuel line upgrade kit
    * Deatsch Werks 800 injectors
    * EGR delete
    * 99 VR4 Clone ecu/cable
    * Blackstealth's LCDBC
    * South Bend stage 4 fe chryo'd clutch
    * IPS lightweight flywheel (not alumi)
    * XYZ 360mm big brake kit
    * PST Aluminum drive shaft
    Update 6/4/13
    * Ray's Ross pistons
    * Ninja Rods
    * Adjusted inj latency settings via cranial removal from fecal orifice...
    A lot of other crap installed before this build...
    Will start adding pics/storyline tomorrow
    Coooooop, hurry up!
    Feb 2011
    Scottsbluff, NE
    Damn Bill, our mod lists are going to be really similar
    1995 Dodge Stealth R/T Turbo
    1993 rt/tt Not Verified
    wa state
    In for pics
    The Panda Not Verified
    Washougal WA/Portland OR
    I don't see any pictures!
    GREASE BUNNY
    VA
    In for pics....on the track!
    Sounds like you are going to be having some real fun.
    JNS Engineering verified
    San Jose, CA
    Definitely in !
    Ok, Let's start with tear down! A big thanks goes out to Nathan (R/T93) for making the 4-5hr drive to come down and help with the fun. We trade the drive depending on who needs the help, but I believe I am in debt to him for some drive time/help!
    Before
    Oh, can't for get it was f-in cold out so I had to come up with some heat. Between this, and a propane tornado we did not freeze
    let's continue
    Pile-O-Parts 1
    Getting the crap out now!
    Cheeeeeeezee!
    Who's cheesing?
    Which one of you clowns is that?
    Wow, that is a beautiful engine bay. What did you use for the carbon fiber look?
    Learn how to Powder Coat at www.powdercoatguide.com.
