I'm using a hand held halo cable, it seems to communicate on 1.3 but not 2.0
I used the tactrix cable which I know is 2.0 and tried the obdII96+ setting with no codes being stored, but again I know for a fact that I had crappy speed sensor that I just changed so it dissapeared without me cleared the code....
Feeling experimental?
Switch bit 11 of periphery 0 on, flash to your ecu and tell me what happens. I'm expecting it to run a little rough but that should turn off the light if Black Stealth is correct.
Give it a try and report back here.
Experiments!at least you're the first.
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
Do you have a manual for your car? I could help more if I had a gto manual. a pdf would be great.
