Page 122 of 155 FirstFirst ... 2272112120121122123124132 ... LastLast
Results 1,211 to 1,220 of 1658
    I lack color... verified
    Aug 1998
    Quote Originally Posted by Vishnu View Post
    I'm in contact with him but this is the first I'm hearing about this particular issue, I'll bring it up to him. If you were to make an educated guess, would this be the primary problem, or do you believe the front and rear o2's are still crossed as well?
    I could tell you if the harness is correct just by looking at it... Rather not make guesses.
    I am 100% confident the cause of the starting issue is the ignition coil driver.
    Berry true, Brett is awesome.
    Quick question, will the write up explain injector, and maf setup in detail? Orrrr, should I get to researching like a mad man?
    all of that info is in this thread. The injector setup is simple:
    Put in approximate latencies and injector size. Car *should* be drive able if you put half way sane numbers in. Drive it around town for 10-15 minutes. Check the fuel trims.
    The latencies have about twice the effect on the low trim as the med trim because the injector pulse width is so low at idle. So, for example.
    Low Trim -10%
    Med Trim - 5%
    Then you need to REMOVE some injector latency so the ecu will open the injectors for a shorter period of time. Log it again until low and med are close to the same. For example:
    Low Trim -5%
    Med Trim - 4%
    Now ADD 5% to your injector size to REMOVE 5% fuel.
    That's pretty much it. Once the trims are good do some wastegate pulls and see if it goes lean. If the afr is safe you can then start tweaking the fuel map if you want.
    www.chromedecu.org verified
    DFW
    @ Vishnu
    You can check the o2 outputs in evoscan 2.9.
    Can you describe your starting issue in more detail?
    What inj settings do you have?
    What inj do you have?
    What rom are you running?
    What maf?
    Your car is a 95?
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
    DC Metro Area
    Quote Originally Posted by Jesters Deadd View Post
    @ Vishnu
    What maf?
    Your car is a 95?
    I'll check the o2 outputs tomorrow in evoscan 2.9,
    Here's a video showing what my starting issue sounds like to me. I'm using my remote starter, but imagine me holding the key in the choke position for as long as I want, occationally it may crank up, but usually it just sounds like this the entire time. It's been tested that the stock 95 fed spec ecu makes the car fire up with no problems at all.
    Vr4 choking - YouTube
    Injector settings are stock.
    Injectors are stock.
    Maf is stock
    Car is 95 Fed spec. Basically the car is 95% stock. I have an intake and exhaust and EBC which is set to 12psi. everything else is stock.
    DFW
    Maf is stock
    If after your car cranks and finally starts then runs fine, then I agree with Greg. Don't worry about checking anything I asked.
    DC Metro Area
    It runs fine after starting, with the exception of the WBo2 showing that it's running rich under cruise and idle conditions. Physically the car feels fine under any kind of (stock level) boost I throw at it. On inspecting what the shop did when they installed my wbo2 gauge, I saw that they plugged the sensor into the rear secondary slot instead of further down where it's supposed to be. Once that's corrected, I should be able to get a better reading as to what's going on down there.
    Hudson, WI
    Vishnu, I'd probably try to verify the pinouts for the coil triggers on your conversion harness. Sounds like it may be trying to fire on the wrong cycle or wrong time or something along those lines.
    -Matt
    '15 Corvette Stingray Z51
    '95 3000GT Spyder VR4 (11.838@117.5)
    Hopewell Junction, NY
    Not sure if I missed it but any word on the evoscan 2.9 file
    2.6 will not work for me :/
    Hey guys,
    If I gut the stock maf, what would be the limit on it? I'm aiming for 450-500 awhp on a conservative dyno, I know the evo maf is a much better option.
