Page 166 of 166 FirstFirst ... 66116156164165166
Results 1,651 to 1,658 of 1658
  1. #1651
    Hopewell Junction, NY
    Hey greg i know i asked this before and i have messed with the tables
    just want to make sure im getting it right
    Startup tables
    At the end there u say to just cut the values in half if your running bigger injectors
    which particular table are you talking about ?
    or is it all of them?
    Intake section
    MAF pulses per stroke 13.06
    does this get changed with the evo maf??
    active exhaust
    so on first gens we need a wire from one side of the conversion harness to the other
    to make the switchable active exhaust work?
    so pin75 on the flash ecu to pin?? on the 1g harness
    also if we use pin 7 to trigger an electric cutout is there some sort of timer cutout ?
    or will it continue to hold the cutout motor in the open position possibly burning out the motor also how would it trigger the close?
    Kx
  2. #1652
    I lack color... verified
    Aug 1998
    Quote Originally Posted by Kx1984 View Post
    Startup tables
    Intake section
    active exhaust
    Kx
    Startup: Change the values in the Cranking IPW table
    Intake: That limitation applies to ALL MAFs. Stock, EVO, MAFT...
    AE: Yes
    Pin 75: Donno what pin that corresponds to on the 1G harness off the top of my head. You'll have to look up the pin outs.
    Pin 7 is active when you make the conditions active in the ROM. So long as all the conditions are met, it's on. No timer. If the motor returns to closed when 0V are applied, then it'll close on it's own.
  3. The Following User Says Thank You to Greg E For This Useful Post:
  4. #1653
    ok good that what i did for the Cranking
    hmm ill have to see what needs to be done with the active exhaust i want it to be functional with the switch
    my friend has one that the switch powers the motor one way and then if u press down it reverses the power to close
    so if the ecu is constant that will keep the relay triggered and burn the motor out
    as always thanks Greg
    Kx
  5. #1654
    Aug 1998
    For something like what you're talking about we would probably need to use the nonturbo VICS motor set up which isn't present on the VR4 ECU nor is it in the code. I'll have to copy it in from the NA ROM and you would need a clone that has those drivers present.
  6. #1655
    European LHD 3000GT TT Not Verified
    Oct 2012
    France
    Quote Originally Posted by Jeff V. View Post
    It logs 2-byte responses just fine. Set it up like this:
    paramname=RPM
    paramid=0x00
    databits=16
    scalingrpn=x,3.90625,*
    This will force it to read requests 0x00 and 0x01 as a proper 2 byte value and scale it appropriately.
    Congratulations ! Thanks man
  7. #1656
    Greg, I have some questions written down at home, is this the thread you want to keep the question/answwers in?
  8. #1657
    Stuper Moderator
    January 2003
    Please see the 1st post. This thread has been locked per Greg's request.
    Quote Originally Posted by Greg E
    Please start your own threads in there (THE ECU FORUM) or add to the topic discussion thread I've started.
    Douches
  9. #1658
    Stuper Moderator
    January 2003
    Guys I've updated the first post of the thread with links to the V2 threads. I've also asked the mods to lock this thread. Let's move all flash ECU discussions into the Tuning, Engine electronics and ECU discussions forum.
    Please start your own threads in there or add to the topic discussion thread I've started.
    http://www.3sgto.org/f104/how-tune-y...ecu-10775.html
    http://www.3sgto.org/f104/chrome-v2-...ual-10777.html
    ^This is where you need to go now^
