Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 71
Thread: Overheating
  1. #31
    I Kill Threads verified
    Wichita KS
    I just went and warmed the car up with the coolant reservoir cap off and waited for the fans to come on, but even at 203F they didn't, so I hit the AC to turn them on. It didn't chug any of the coolant from the reservoir either. And checking after the drive it hadn't used anything. I did notice there was bubbles coming from the reservoir as the engine ran, so there must be a leak somewhere allowing air in.
    Went for a drive after it was warmed up, and even with the AC on it only regulates the temperature slightly better. Still will get up to 230-235 and if I cruise for long enough (say I miss a light) then it'll drop down, but it'll soon come back up to about 223.
    I think a blockage or leaking cap would be the most likely cause now, would that be a good assumption? I'll call some places and see if they can check it soon.
    1992 3000GT VR-4
  2. #32
    I'm Kind Of A Big Deal
    if your radiator fan isn't turning on... then I would start from there. If there were a blockage or a leaking cap, the fan would still turn on when it gets too hot.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
  3. #33
    Twin Turbo verified
    Melbourne, Australia
    Quote Originally Posted by Goallie11 View Post
    This sounds very much like a head gasket This is what mine did when I had a blown head gasket.
    Waiting install
    Build Thread
  4. #34
    if, once its warmed up, you turn it off and it sounds like gurgling...you really should look at the rad cap. swapping mine out fixed this issue for me.
  5. #35
    Wichita KS
    I just got back from an extended drive from what I normally do and the reservoir was definitely gurgling and the cap was hissing, it also leaked a little bit... So it's looking more like a bad cap.
    Emilie what temp is too hot? I would assume anything above 190 as thats what the thermostat is?
    JOE I really hope it isn't a head gasket, tomorrow I can go get a new cap since I have most of the day free.
  6. #36
    August 2003
    Uniontown
    Hey, I tried this to find I had good gaskets. Just one HUGE air bubble after changing my pump out. (my fans worked)
    Combustion Leak Detector, FREE SHIPPING!
  7. The Following User Says Thank You to EvanH For This Useful Post:
  8. #37
    August 2003
    Uniontown
    Hey steve. That same kit was recommended in Popular Mechanics, in the June 2010 issue. So please stop trying to pawn everything as rice, and go raid more junkyards. No wonder you keep breaking ring lands, and blowing engines.
  9. #38
    I fix them before they get to that stage.
    Steve
    just 28 counts of knock too bad your ecu cant read any more. maby you could add another ecu so you could atleast read 56 counts of knock combined just like twin fprs and stuff .
    I apologise for being far off topic again but I can't help myself
  10. #39
    Quote Originally Posted by EvanH View Post
    gonna buy one myself .
  11. #40
    That's what you do on ALL cars with overheating problems.........my cars don't have overheating problems because I fix them before they get to that stage.
    That's because if you keep on driving them they get worse and more expensive to fix.......popped hoses, popped rad, popped heater, leaking waterpump, bent valves.
    Steve
    So, you're saying that the way to check for a headgasket problem, is to turn your car into a boiling hot geyser?
