Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 71
Thread: Overheating
    I Kill Threads verified
    Wichita KS
    Just checked the car out and the fans definitely aren't coming on, I pulled out the small fuse that says 404 but it didn't cause either to come on. Couldn't get the bigger fuse to come off, but I'll try again.
    Now that I think of it though, I do have the AC control computer unplugged, I'll plug that back in and see if the fans restart.
    After lunch though.
    1992 3000GT VR-4
    Wichita KS
    Ok so I fixed it, plugged the AC controller back in and the fans come on now. Stupid me for not plugging that back in sooner.
    lol. user modification fail.
    Wichita KS
    Well unfortunately it looks like plugging that back in hasn't fixed it entirely. I'm cruising at about 220* and my needle is showing just below half, like normal.
    But it still overheats at lights, but now it falls much quicker back to normal. So maybe my big fan isn't working? I'll have to check sometime tomorrow.
    Key Largo, FL
    You might have a blockage in the radiator. Have you had it flushed recently? If not, it's worth a try. I had similar problems a few years ago except my car would over heat when climbing hills on hot days. A good flush fixed the problem.
    2013 NG: 1st place, FWD Drags
    could possibly be a pin-hole leak somewhere. ask me how i know.
    Ti/AL goodness Not Verified
    Mar 2011
    Thats what i was thinking. The cap or a small hole letting in air but not letting out coolant.
  8. #18
    Twin Turbo verified
    Melbourne, Australia
    Check your cooling system. I had a blown head gasket a couple of years ago and while gettign that fixed I also had my radiator proffesionally cleaner and refurbished and the report stated that it was 70% blocked yet I never had a single instance where the temp got above half way [with the exception of the blown head gasket caused by a leaking heater hose]. The cooling system in our cars is very good and if you having issues and it's not the fans or the headgasket then it could have a serious blockage. I would recommend changing all heater and rad hoses, new thermostat, new water pump, rad cap and clean. No point doing it unless it's done properly.
    Waiting install
    Build Thread
  9. #19
    Wichita KS
    I'll see this week if I can have it checked for blockages. Hopefully it's not a headgasket but I've feared that for sometime now.
    Might as well get a new radiator cap just to be sure it's not that and then move on to the other stuff from there. If I were at home instead of college I would of course have more time and a garage to do this in, but unfortunately don't have much options up here.
    Would it be better to get one of the aftermarket caps on 3sx or a stock one?
  10. #20
    Honda Eater
    April 2007
    Ontario, Canada
    no white smoke out the exhaust?
    check your coolant level.
