Page 1 of 8 123 ... LastLast
Results 1 to 10 of 71
Thread: Overheating
    I Kill Threads verified
    Wichita KS
    Overheating
    So recently my car has been overheating more frequently to the point that it does it every time I drive it, fortunately I mostly have to make short trips where it doesn't get to the point of overheating but thats not always the case.
    It happens when I'm driving, and especially at stops it'll rise pretty quickly, but then after either a few seconds to 20ish of driving it'll just drop back to normal. I don't seem to be leaking any coolant, but I did notice some when I went to the dealership the other day, otherwise the coolant reserve tank has remained about constant in level.
    What really concerned me was today while out I got random 16 and 15 counts of knock, but the engine didn't hesitate or anything out of the ordinary when this happened. And this is the first time it's ever happened since I started overheating.
    Could it just be that I have air trapped in the coolant? It seems to happen too frequently for that, as I have had that happen before. I assume both my fans are coming on and they help a little when on, but it still overheats but not as much. I'll check out the fans working tomorrow. Could I need a new radiator?
    1992 3000GT VR-4
    Canaan NH
    Your fans are not working.
    Check out the new 3sgto chat room.
    www.chromedecu.org verified
    DFW
    Same thing happened to me... it was my AC fan that was bad.
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
    Wichita KS
    Ah good to know, I was afraid it'd be something worse. I'll confirm tomorrow that it is the fans
    ....or your temp sensor is shot. and it never hurts to replace the rad cap--especially if it's OEM to the vehicle. before i replaced my cap, i could literally hear my coolant bubbling when i parked the car.
    Wichita KS
    Assuming it is the fans not working whats the recommended course of action?
    Wichita KS
    Shouldn't be the temp sensor, I replaced it with a new one not too long ago. Radiator cap might be worth doing though, a little preventative maintenance never hurts!
    Canaan NH
    If when the car is hot and the fams dont comw on you need to track why. I believe they are operated by turning on the ground through a relay, that should get you started.
    Open the fuse box on the left and look for FAN HI relay. Squeeze the relay cover and pop it off, then pinch the relay. THe fan should come on.
    Also do this with the AC condensor fan on the right side fuse box (smaller one).
    DFW
    Quote Originally Posted by marshallh View Post
    Or you can use evoscan to activate them...
