Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 71
Thread: Overheating
  1. #51
    in for vid of anyone doing that to steve's car while steve is under the hood.
  2. #52
    I'm Kind Of A Big Deal
    not even worth my breath. Good luck dude. You're a joke.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
  3. #53
    Fixed.
    Of course you can take the cap off when it's hot.
    It tells you how to do so in the owners manual......carefully.
    Only broken engines give geysers
    Steve
    Let me just quote this for the sake of my sanity later. So I can come back in here and laugh, in case you go on a deleting spree
  4. #54
    Am I the only one that does a leak down test to diagnose leaks? I know this thread has derailed but I never seen anyone mention it.
  5. #55
    Cazenovia, NY
    They don't work 100% of the time.......it's another ricer part.
    They're only for mechanics who don't know how to diagnose overheating problems.
    Same as a teekay test....useless.
    Half the time the test tells you it's OK so you go running round in circles looking for something else, when all you n eed to check for is bubbles coming out of the filler neck.
    Steve
    You sir... are a fucking retard.
    So mechanics are supposed to use their eyes and their eyes alone to address a possible head gasket issue? Can you see a head gasket? No... and that's why we use TOOLS to aid us in diagnostics.
    Those do work... they detect hydrocarbons in the fucking coolant, which there is an acceptable level of, and is very low. If exhaust is getting into the coolant, that shit will let you know.
    A leak down test would be a BETTER idea with the radiator cap off. Slowly increase pressure so you don't take the risk of spraying coolant everywhere, and observe any bubbles that may appear. I bet a leak down tester is a rice part too though... so maybe you don't listen to me?
  6. #56
    BTW Steve that car in you avatar... Is that a joke or did you really do that to your hood? I can't imagine a car ever overheating with that kinda turbulent airflow.
  7. #57
    yes he did ..
    you jelly ?
  8. #58
    Banned J. Fast's Avatar
    According to the Motor Week radio/talkshow Steve is correct in saying bring the car up to temp with the cap off. The only difference is you don't diagnose it by looking for bubbles. You use a gas analyzer. Pat Goss from Motor Week talks about how to test it that way on his show all the time. He removes the radiator cap, siphons out a little coolant, and has people hold their cars at 15-1800 rpm till it warms up. While they are holding the car at steady state RPM he holds a gas analyzer over the radiator . If it over pressurizes and pushes coolant... the gaskets bad. If the gas analyzer picks up hydrocarbons, the gasket is bad. He said the only way to test for headlift or a bad gasket it to build equivalent block pressure because sometimes a head gasket wont leak at idle when the water is at 20psi.
    Don't know if this Motor Week talkshow Pat Gross guy is right or wrong, however I have heard that it is okay to bring your car up to warm up temp with the radiator cap removed.
  9. #59
    have you guys seriously never had your radiator caps off when the engine is running? How do you burp the cooling system if you don't?
  10. #60
    Twin Turbo verified
    Melbourne, Australia
    Buy one of these and run the car. Fil the bucket and then pump all the hoses with your hand. Eventually all the air should come out. If it's still constanly bubbling then you have a problem. Basically what Steve is trying to say just using a filler bucket instead of looking down the cap.
    Lisle LIS22150 Coolant Funnel w/ Radiator Fill Adapters LIS22150 | Cooling System Service
    Waiting install
    Build Thread
