Pulled out the stock injectors and replaced them with the big ones. Went out for a cruise to set the fuel trims. Looking forward to moar boost....
new oily coolers.
You running Evans Waterless NPG mb7050? That's a lot of oil cooler.![]()
Installed my new 2nd gen skirts. Still need to throw the new fender on as I was at my dads and forgot it.
Also removed my damaged rear bumper and preped my new rear bumper for paint and will be spraying it tomorrow.
This car will once again be clean!
Spent a bit of time working on resetting timing then hurling obscenities (and tools) when I noticed on my workbench..My spark plugs from the front bank. Damn front cylinders have been open to the air for the last month while I was in NY. While there is no water leak over the engine, I still worry about just moisture in the air or any blowing in during rain.. :/ Going to blow the cylinders out with compressed air and have to hope for the best I'm afraid. Still kicking myself over leaving it open, could've sworn I put them back in but I guess I only remembered to do that back.
Don't even want to think about that. Thankfully they haven't been very bad this year though. Debating now about maybe if i should go ahead and pull the front head off and check. Or maybe I'll just use a light and see what I can spot. Perhaps some carb cleaner or similar and compressed air? Suffice to say Paul, I should've brought some moonshine back with me.
Could have used the moon shine to clean the cylinders.![]()
lol Could've, but the way I feel at the moment, I think that would be a waste of shine![]()
I'll have to hunt around the house, we *may* have some around here provided it hasn't been polished off yet.
