Thinking ckcckchcckckckk, ckckhckchhhckkckkkk
bought a new 4 bolt engine and heads to swap in to the 92 to fix the crank case overpressureization issue im currently having.
other than that had my hot water heater crap out in the house
Filled up with 100 octane and did some joy riding![]()
Drove it to work today. One of these days ill figure out why my DS likes to make noise from 30 to 55 =/. Installing poly rear diff mounts to the Y plate on the rear diff today when I get off hopefully.
yes, its a 3m di-noc
Opened the '91 TT up to install '99 lifters, plugs and wires, and to clean things up a little.
Sent from my Nexus S
Yes, just used aluminum piping off eBay. Vibrant is the only one I know of that does aluminum mufflers. $150 if I recall for a 4". You could vband a stainless on but the vibrant alum only weighs around 2.5-3lbs.
I have the exhaust complete and it's better but a hair too loud. One muffler/resonator should do it. When I get around to it.
Installed intermediate shaft for auto. Wired shiftbox. Wired lock-up converter switch. New tires for rear. And got it off jackstands!
Oh and I drove it around the blockFueling tune needs a lot of work but it's going to move pretty good once sorted. VERY happy that the Auto doesn't kill the fun at all so far (I had my concerns). I'll have more to report on auto vs 5sp later but for now, it's badass. 1st to 2nd shift with the shift kit and shiftbox is retarded fast and fun. Surprisingly responsive with 280's and a stock converter on this quick trip.
Nomie, I know you are watching....you are toast buddy![]()
Awesome, I love the feedback on the auto. I need to find a shell with no trans and no engine. I can throw an auto in it and my old engine, lol.
