Sitting a little lower today. Springs must be settling
Looks good. TEIN S Techs?
Yeah, the rotors I bought from IPS are mounted the same direction n2sanity mounted his. The directions (or IPS jeff) specifically said to mount them that way. I didn't think to look at the internal cooling passages, but I will next time I'm in there. They've certainly stopped the car from very ..... legal ..... speeds.
More like this weekend for me, rather than today but got things accomplished nonetheless....
Front head reassembled with 99 lifters, new VSS and preset cam gears, new plugs in both heads, new wires installed on front, transmission reinstalled (new clutch and 300m OS).
New bearings and oil pump + rear head work and timing planned for next weekend. So close I can taste it...
got a few toys
battery/FPR mount/tray
with battery mounted
and cutoff switch - more to come on that, later
200 amp battery isolator
beefy battery terminals (3x 0gauge inputs - can also use 4 studs for ring terminals.)
and a 6 to 3/0 gauge crimping tool
more electrical toys in the mail to be arriving soon =D
-jeff
1992 SVX LS-L
1996 3000GT FWD-TT
2005 XC90 T6 AWD
i collect parts.
Are you relocating the battery?
I've already been running an Odyssey 925 in the back, I'm going to keep that there for stereo, fuel pump, other accessories, etc. and run the 680 as the starting battery up front.
Got the rear shocks put on today, she rides alot better than she did on 23 year old shocks. Alas....the right rear is still learning in a bit.....doesnt look like the control arm is bent. Will investigate more later.
Sent from my DROID4 using Tapatalk 2
