Page 159 of 166 FirstFirst ... 59109149157158159160161 ... LastLast
Results 1,581 to 1,590 of 1658
  1. #1581
    Switching that bit off shouldn't effect your AFR in any way. All they do is disable the branch that checks for those faults. Every bit in periphery 2-4 is that way.
    I'm really starting to wonder if your front/rear sensor inputs are switched. It's easy to swap pins to test this.
    Really quick, can you post your periphery 0 settings?
  2. #1582
    Dec 2012
    The conversion harness should be the correct version as I just recently purchased from Brett. I will double check on the pins.
    Periphery0:
    bit, 1,2,4,7,12,14 are all enabled, the rest of them are off.
  3. #1583
    Dec 2012
    Just checked the front/rear sensor pin inputs from the conversion harness - Pin75 to Pin71 and Pin76 to Pin72: I believe they are switched as intended because Mitsu manual is supposed to be incorrect based on what've read. Any how, I switched back to the way described by Mitsu Pin75 to Pin72 and Pin76 to Pin71. Started up the car and voilà, A/F now hovers between 14.6-14.8 Greg, thanks for your help!
  4. #1584
    Glad to hear it!
  5. #1585
    Oct 2010
    St Louis
    Quote Originally Posted by saiteiman View Post
    Interesting enough that is what I had as a Cali setup . . . Pin 75 to Pin 72 . . . hmmmmmm I have only done one other hybrid car. I will note this on my build sheet and see if I can put my hands on a hybrid FED car here in st louis to physically test out the harness. Sorry for the confusion.
    Brett
    www.ClonedECU.com
    Get Chromed!
    1999 3000GT VR4
    Glacier Pearl White
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
  6. #1586
    Quote Originally Posted by 99 vr4 View Post
    Brett
    That would be easy enough...
  7. #1587
    So I am guessing I will need to switch a couple things as I have your Hybrid fed cable Brett?
  8. #1588
    Oct 2010
    St Louis
    Not unless it's wrong... Lol pin 75 to pin 72 on the flash ecu side for a fed. If your running closed loop without any issues, then your ok.
  9. #1589
    OK, not running it yet, I need to get it in there before I tear it down the 28th.
  10. #1590
    European LHD 3000GT TT Not Verified
    Oct 2012
    France
    Can you verify if O2FRONT is 0x3E and O2REAR is 0x13 ?
    Because if you switched 71 and 72, the result is inversed ?
    You can test it easyly by disconnect the front O2, and show result in EVOScan by "0"
    I don't understand, it's switched here: http://evoecu.logic.net/wiki/MUT_Requests
