www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
No, they just don't flow enough air. I've run into this problem with every single upgraded turbo car I've tuned. Even on my completely stock car, the most I can get with the restriction pill removed is 18psi. I'm also tempted to try setting it up as a "blocker" instead of a bleeder. This way it would work like most aftermarket boost controllers do. It's very simple to setup.
Don't be going around giving guys the idea that a flash ECU will solve open atmosphere BOV issues.
Wether or not you notice or care, you will run rich between shifts. This can usually cause issues. Some people get away with it because they have the springs set very tight on the BOV so it doesn't vent as much air.
I can't justify the drivability issue for something that "sounds so awesome"...
Right? Haha. Even with a tightened Type-S and R on a fully-gutted MAS prior to MAFless/SD tunes, I would only see a "best" of 12:1 [down to 11ish] between shifts. I have even made plots with a TiAL using both 9&11lb springs.
Any luck with the GM, AEM/MAC, or Grimspeed solenoids yet? I believe that the former is the "slowest" of that bunch lol.
-sent from myTouch 4G Slide
