Just remember that any PIN 35 custom out will create a new "FORK" of code as that code will not be compatible with a 1998 or 1999... Pin 35 is used for the EVAP Vent on the 1998 and 1999 . . . unless it is switchable via the peripheries . . .
www.ClonedECU.com
The home of the Original Clone and Clone2 ECU!
More Plug n' Drive and less Plug n' Fail like the others!
Remember, if it's not a Clone, it's just a copy!
Get Chromed!
Donate Now and receive a coupon code for the amount of your donation (up to $50.00 US) which you can apply at check out for a Clone2 ECU, Plug n’ Play Harness, or Clone2 Plug n’ Play Package!!
1999 3000GT VR4
Glacier Pearl White
Yeah it's stock . . . trust me
How To Contact Me:
eMail: brett_farnam@yahoo.com
US3S/3SGTO: 99 vr4
3SI: bfarnam
Jimmy, I verified your VIN. Your car is a FED spec car. P1300 is not a valid DTC for this platform. Are you logging this DTC with EVOScan 2.9? Please download EVOScan v2.6 and check the DTC with the older version. The newer version does not report the DTC correctly. We are trying to get this fixed but this is an EVOScan issue.
Also can you please tell me what bits 13 and 14 are set to? These should be off. If you change the bits, you will need to use EVOScan v2.6 to check and CLEAR any DTC's.
Yeah evoscan 2.9 is messed up with reading DTCs. If you try to read them even when the CEL isn't on, it'll still show you erroneous codes. I've given Hammish a heads up with this but haven't heard back.![]()
Ah okay! I question the accuracy of that device too. I can say this with a lot of confidence, if you don't see the DTC in the peripheries, its not used in the code. Best to use evoscan 2.6 for reading and clearing codes.
You should also turn bit 13 off in periphery 2. Your periphery 0 setup is correct.
Okay, just turned off bit 13 in periphery2 and observed the following symptom:
Now the A/F goes up to 17-18 with F.O2 (3E) at 0.0xV & R.O2 (13) at 0.8xV. At the same time, F.O2 STFT is at -15.xx% and R.O2 STFT at 12..5%.
A moment later, A/F goes down to 11 with F.O2 at 0.9xV & R.O2 at 0.0xV.
It is apparent that both front & rear O2s don't agree to each other.
