Page 275 of 892 FirstFirst ... 175225265273274275276277285325375775 ... LastLast
Results 2,741 to 2,750 of 8916
  1. #2741
    Quote Originally Posted by terrets View Post
    I know but I need to replace them.
    How the hell am I suppose to get it out? haha.. I don't have a torch to heat it up...
    And I don't want to drill it out because the new one wouldn't go back in correctly...
    And I don't want to get new hubs, because money...
    use a ball joint puller. I always pull it loose at the strut bolts though.
  2. #2742
    if you ever came in chat, I'd explain it.
  3. #2743
    SKADOOSH!!! verified
    Prince George
    Started working on my widebody fenders!!! 4" all around...
    Photobucket
  4. #2744
    Advanced Tech? verified
    wait, why are you guys popping ball joints to pull the trans?
  6. #2746
    No sheep are safe tonight supporter
    Dandridge, TN
    Last time I removed a tranny, all I had to do was unbolt the lower passenger strut mount, was enough play to get the PS shaft out of the tranny. Never touched the driver side axel at all... the tranny slid off it with it in place.
  7. #2747
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    I used to pull the brakes, center hub castle, and lower ball joint castle nut and smack the hub and control arm with a 5 lb sledge. The ball joint would release and drop down the control arm and it all swiveled forward.
    It's a very heavy handed way to do it, but it's very fast removal doing it that way. I learned that removal technique from a Removal Technician at AAMCO. Taught me how to drop a trans in under an hour. Props to that MOFO...
  8. #2748
    because it's FAST and doesn't mess the alignment up.
    J. I don't even touch the brakes.
  9. #2749
    Man vs 3/S verified
    Kingston, WA
    Yep, big hammer and a brass punch (a big one), comes right out, LCA then drops way down and can pull axle easily
    From the phone.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  10. #2750
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    Guys, my problem isn't getting the axles and transmission out, it's the tie-rod ends that are stuck! What if I can't get them out, can they be drilled out or is the hole tapered like the tie-rods?
    Quote Originally Posted by TwIzTeD_3kGt View Post
    Bigger hammer.
    I hit those fuckers as hard as I could.
    Quote Originally Posted by J_Parker View Post
    Got a thread for this???
