Page 277 of 892 FirstFirst ... 177227267275276277278279287327377777 ... LastLast
Results 2,761 to 2,770 of 8916
  1. #2761
    94 3500gt vr2? verified
    NC
    Cleaned up my splash guards and started installing them. Every single piece of plastic has been off for the past year, lol. Sprayed some undercoating in the wheelwells. Starting to look like a complete car
  2. #2762
    SKADOOSH!!! verified
    Prince George
    Started scrapeing out the sound deadening, and cutting out some sheet metal today, my goal is ~1,000lbs gone by the end.
    Photobucket
  3. #2763
    Apr 2011
    Mid-April 2011.
    Monroe WI
    lightly hit a construction barrel that some RETARD thought itd be a good idea to set in the perfect center of a on ramp after a corner where you could not see it. after locking up the brakes and then almost being rear ended, I lightly tapped it, and got out and threw it over the guard rail in a half rage.
  4. #2764
    Easton
    Trying to fix my high idle problem. Passed the pressure test and IAC tested fine after it cooled down a bit. Still working on it.
  5. #2765
    Easton
    Fix my idle problem and installed my gzp side mount oil cooler. No ducting yet and oil temps dropped over 20 degrees. Luckily I did it now because one of my lines was leaking.
  6. #2766
    One fix at a time verified
    Kansas
    Yesterday I installed new speakers. I was going to drain the tank today, fill it with ethanol, swap my new injectors in, and tune the car but the only gas station in town that had it was out so I only got 3 gallons out of the pump. Lol. It's sad that not too long ago there were about 7 stations around town with it. They either went out of business or changed owners and ended up switching to carrying diesel instead.
  7. #2767
    you know you like it Not Verified
    Sacramento CA
    Drove it Saturday and put 17Gallons in it on Monday lol
  8. #2768
    Kansas
    I got new turbos in the mail. Woot!
  9. #2769
    Jan 2011
    az
    What kind??
  10. #2770
    Essex, UK
    Took more off mine... awaiting BC coilovers
    Car looking unhappy!
    Paul
