Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 74
Thread: CX Racing 70mm Throttle Body Question
  1. #31
    ^ If you look at that link, it`s got a bearing in the same places as the CX racing one, how do you know it`s sealed properly behind it?.
  2. #32
    SoSoCal verified
    sowhat I am heating it needs togo to a machine shop, april u got one close by that knows what they r doing and whome you can talk to in person?
  3. #33
    TN
    Quote Originally Posted by DuTTch View Post
    No, and time is a huge factor right now. I'll send you a PM with what is going on. Replacing a the seals would be at most a two hour job for disassemble and reassembly. But well now it is an entirely different case. And the response I got from CXRacing was "can't find your purchase history" LOL... assholes.
  4. #34
    Stuper Moderator
    January 2003
    Quote Originally Posted by dbest671 View Post
    Wow, class act there...
    Douches
  5. #35
    Huh? verified
    Detroit Area, MI
    Quote Originally Posted by TUFFTR View Post
    Plenty of 70mm TB's made for an EVO and I'm 99.99% sure the TB's off a 4G63 bolt onto a 6G7x manifold
    BRAND NEW MITSUBISHI EVO 7 8 9 THROTTLE BODY 70MM 4G63 | eBay
    You'd have to swap to the evo tps and isc though, and the evo tps doesn't have an idle switch.
    1993 3ooogt vr4
    Big single turbo and every other mod...
    Powered by BorgWarner
  6. #36
    I have been asked to look at this problem and creat a cost affective repair. My biggest question is how many still have theirs and wished for them to work correctly?
    And, what is the cost repair target you guys are looking for? Does anyone know if CX has a boat load that needs repair as well? All these questions have much to do with getting the repair cost down to
    a level that most are willing to pay.
    Mods
    OBX long tube headers, Flow master single 3" in with dual 2.5 outs. VR4 runners with 2 liter plenum, port matched lower intake, stage 3 or better race prepped heads with 1 mm oversize Rev valves, Rev race dual springs and Rev keepers, Delta/HKS 272 cams, 3SX adjustable cam gears, 3.0 Cobra Mustang Throttle body, 3.0 LT1 maft and Maftranslater gen II, Alum. Flywheel, Spec stage 5 clutch, VR4 injectors, Wizard wires, Unorthodox under drive. IPS fuel rails w/adj FPR, Fuel loop, Walboro 255 hot wired, Hot wired single fan. Short shifter, Battery relocate. EBC front slotted rotors, EBC Yellow stuff Pads, 3SX SST brake lines, sway bars, springs.
    No IAC, NO AC, NO extra weight, VR4 ECU as of NG2011. Still 10 to 1 slugs, Nitto NT05 Competition Road Course Racing tires. Magan coil overs, 3sx adjustable rear links.
    http://www.youtube.com/watch?v=2s0I3tnGGmg
    1st place fastest NA - Drag - TXG 11 98mph, 1st place quickest NA - drags 14.773, 1st place Dyno - TXG11 229 FWHP & 236 tq, 2ND place Auto cross NA C/S- NG2011, 1ST place NA dyno - TX gathering 2010 - 229 FWHP & 199 tq, 1st place Fastest NA - TXG 2010 - 98.3 trap, 1st Place quickest NA - TXG 2010 - 14.680, 2ND place 1/4 at NG10, best NA time NG10 - 14.932- no traction, 2ND place 1/4 at NG09,
    2ND place Autocross NG09
  7. #37
    TN
    I know of at least four people with the problem. However two of them are in the UK. I am sure there are many other out there, but it would probably require another thread.
  8. #38
    I'm Kind Of A Big Deal
    Did you buy it directly through them, or through a 3rd party? Your purchase order would have been emailed to you with your tracking number if you purchased directly from them.
    I would be happy to talk to Kevin on this, if you guys have some ideas for a solution. He has always been very pro-active with improving the quality of his products for our platform, and making new products. In some cases (like their TD05 kit), the kits are designed by an outside company, and then sent to CX Racing for production. If they are not built properly the first time, then everything else is bad. They do not have a car there to do final testing on, so they rely on the person(s) who designed the product
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
  9. #39
    TN
    This is not my throttle body, it is DuTTch's. And I believe it was purchased through SSM. I know in other threads about this TB, Jesse said he was working with Kevin on a solution. I know somebody got three different throttle bodies, supposedly rebuilt by CX Racing, and all the "rebuilds" leaked like the original if not worse LOL.
    And gltasn also receive a "rebuilt" TB, which also leaks. So, apparently they didn't fix the problem.
    If this was just a one time case, I could understand the response by CX Racing. But this is an ongoing issue, has been. I asked if they had found a solution to correct the problem. I didn't ask for a new throttle body or parts, I just wanted to know if they had a solution in place.
    http://www.3sgto.org/f54/70mm-billet...-now-3579.html
    http://www.3sgto.org/f2/crx-racing-7...call-5686.html
  10. #40
    If the order was placed through SSM, I doubt CX Racing has any way of tracking it, other than an SSM purchase, and there's no way to trace it after that.
    They don't necessarily have the means to figure out a solution to the problem. If you can come up with something, or a direction, let me know, and I will happily bring it up to Kevin and try to get it addressed.
