This just started happening recently after installing rebuilt TB and reflashing my chrome to fix my fuel trims.
If I ease into the throttle ill have no problems, accelerates fine all the way to WOT.
If I floor it from 1.5k it will run lean.. around cruising afr, went as high as 16 the first time it happened.. havent floored it since.
If I rev at idle, near redline i get ~2 counts of knock.
Im thinking fuel delivery issue, pump is wally 400 hotwired, 43psi at idle. boosting @ 12.5psi
any ideas?
__________________
, and no knock when at 10:1.
