yeah mine came thru ssm.The Wizard is is on it. April is gonna ship it to him.
If in fact, the equipment used to manufacture these units, And the programers that programed that equipment had an understanding of true location and tolerancing, than these unit mat well be repairable.
That fact that they had no clue at all about throttle shaft bearing may not be an issue. But again, the same hold true for the throttle shaft itself. If dimentional tolerancing was held, these units again may be repairable.
It all bepends on the quilty of the machine work and their quality control department. If in fact all these units are exactly the same, and the bores for the bearing are in true lacation, than the rest is easy. The best way to even think about repairing these units is to have 4 or 5 units for evailuation to how well tolerances where held from unit to unit. Than a kit can be made that uses "REAL throttle bearing". True throttle bearing will not only hold boost, but hold vacuum as well. It is easier to hold 100 lb.s of boost, than it is to hold 30 lb vacuum. If holding vacuum is possible, than there will be noi boost issues.
Mods
2ND place Autocross NG09
April,
Do you have an intake manifold that was set up to run this throttle Body? Modification like this one for Mark will be required to run this throttle body.
or you can also see the here.
Yoh! Big mouth - 3000GT/Stealth International Message Center
No, I have no reason to have an intake like that. My car, for the most part, is stock with some "ooohhh pretty" mods. I have Mark's 70MM throttle body, I was going see if I could use OEM type seals for the shaft to fix the leaks.
Question for you... do you want the TB put back together or left disassembled? I asked Mark, and he said probably disassembled. I can get it in the mail today if I don't have to put it back together, PO closes at 11:30 here.
My 79mm (3.110 in) Cobra throttle body is only a 3 wire. Not a problem at all. Add an external switch that is ativated by the bell crank.
Not yet, hoping to get an answer to my question from GTWizard... it will go in the mail Monday morning via USPS priority, so it will be there on Wednesday. If he doesn't answer, I will just ship it disassembled.
Ah. Hello?? April, your wrong.
The reason you need this intake mod is so you can run that throttle body.
That 70mm throttle body will not open all the way on a staock manifold. The butterfly hits the opening. So, yes you do. That was why I Moddified Marks.
So he could run that throttle body. If you are not moding you upper penum, don't waist my and your time shipping the throttle body. As it will not work for you on a stock intake.
If you wish to understand more, than you have to listen. Go ahead and bolt the throttle body in place as if it was a working unit. Now try to open the throttle body to full open.
You will find it only opens about 1/2 way. The other thing to realize is if it did bolt on and the butterfly would open all the way. Your performance would be less do to the small opening
at the face of the plenum would cause so much tubulance not any more than the stock flow rates would get through it.
Go back and read "Big Mouth" in the link I posted. It was posted so you have a better understanding of what going on here.
If you do not wish to enhance the performance of your motor. Why even bother with this mod if you are not going to take advantage of it. Kida silly.
As far as the throttle body itself. There are no seals you are going to by that will work.
There are special bearings just for throttle body shafts. I don't even know yet if the shaft in those damn things are a shaft the will even except a true throttle bearing.
No need to get it in the mail today. I am installing a motor in a customers build at this time. If I had the body and would start taking a look at it and see if it is made well enough to except
a kit. I only had that body a short time. never much looked at it other than to mod the intake. I know what wrong it. And know what it needs.
And I know your needs.
When making mods to a car. Pleace concider the 3 Fs.
Fit - and this does not
Form - poor design
Function - this doe not.
You are asking me to correct one part. You need all 3 fixed.
Assembled or not is fine.
It's NOT my TB, I have no plans to use anything other than a stock TB. I was going to see if I could fix it for Mark. I know what exactly what you are saying, so it's not that I'm not listening to you, it's just it doesn't apply to me.
This IS Mark's TB that I have BTW... and I'm going to send it to you per Mark's request.
