im using a autozone one too. Its got a blue blody where the awd one is gray i think.
I was worried about getting the surging issue after my FMIC install but after doing some test runs afterwards I got nothing?!?!?
So is the surging issue only a problem with larger turbos?
I'm still on stock turbos at 14psi and I have no surging..........
Finished up the exhaust test pipe. Picked up temp tags and went for a loong test drive. No leaks
Needs a washin'. Time to come out and play for spring.
just picked up a cx racing fmic from ray. has anybody here ever ran the hotside pipe on the front turbo under the car with a cx kit. it kinda looks wierd with the hotside pipe coming across the way like the kit is supposed to. i know ill probably have to do some mods if i want it like that or however.
Bought some parts and fluids. Maybe I'll finish building the motor this year. Maybe
EricC
How much does that cx racing kit run?
1991 Stealth RT/TT
