Page 684 of 892 FirstFirst ... 184584634674682683684685686694734784 ... LastLast
Results 6,831 to 6,840 of 8916
  1. #6831
    Drove it for 10 minutes, got to try out our village's new pavement, parked it back at home, went to the Rally/wrench in my truck, took a pic of Pastrana's car as it passed, came home.
  2. #6832
    I don't understand why the chamfer would go down. Wouldn't that leave an airgap under the brace unless you counter sink and match the chamfer perfectly?
    With chamfer out, you have a good place to weld.
    Maybe in visualizing wrong and someone can straighten me out.
    yeah I don't get it either, but I saw Ray posted it that way. I imagine as long as the gear set fits its not a huge problem either way.
    sneak peak:
  3. #6833
    Sep 2012
    Decatur, TN
    sneak peak:
    Not like the strength of the bracing comes from the chamfer being up or down, I imagine it just helps account for the radiusing where the vertical and horizontal meet. Still too big for that though. I agree the chamfered portion makes a more ideal area to weld.
    Color me jealous of the picture. Just hope I'll be here when Chris starts tearing into mine, doubt it though.
    These all need to be torn down first for either salvage or rebuild before mine gets looked at.
  4. #6834
    One fix at a time verified
    Kansas
    The input shaft bearing is super easy to change if you have a press. I used a Harbor Freight 20 ton but I bet the 12 ton will work also because it doesn't require too much force. A 32mm socket works great for pressing it in or out. You can press the bearing too far in upon installation so measure how far your old one protrudes into the bell housing. I've tried feeler gauges but a dial gauge would be more precise. If you go through that trouble you might as well reset the bearing preload for the input shaft.
  5. #6835
    San Francisco
    After still being frustrated by wandering steering, even after replacing a howling wheel bearing and both sets of inner & outer tie rods and both ball joints, I decided to replace the other wheel bearing. Just a little loose!
    Support NG!
  6. #6836
    Oct 2011
    Sundsvall, Sweden
    What type of puller is that?
    Seems to be a good one for pulling the bearing races.
  7. #6837
    Sep 2012
    Decatur, TN
    It is a puller for GM rear differentials iirc. The jaws are pretty small so you can get them under the races. Pair it with a slide hammer and you're good to go pretty much.
    Unfortunately I don't know much for specifics on it. The feet/lips on the jaws are very very narrow and there's not a ton of material under them to keep them from getting under either.
  8. #6838
    West MI
    Kent Moore DT-47865 is the part number
    92 3000GT VR4
    Matt
  9. The Following User Says Thank You to sublime_whatigo For This Useful Post:
  10. #6839
    August 2010
    Chicago
    first time with a dslr...just testing it out...
    34XXlbs..
  11. #6840
    I love that someone is running the same wheels and hood.
