Page 182 of 892 FirstFirst ... 82132172180181182183184192232282682 ... LastLast
Results 1,811 to 1,820 of 8916
  1. #1811
    didn't know you were getting surging, paul. keep us posted on how/what you use for balancing it.
  2. #1812
    SKADOOSH!!! verified
    Prince George
    So, I did some experimenting with some different paints, and here's what I came up with. I was using a GM paint called Torch Red. After spending some time comparing that was the very closest I could get to our own Firestorm Red.
    What I had done was use two different primers to see which one would darken, or lighten the color of the Torch Red to make it a more acceptable pair with the original on my car. In the pictures, you can see the sideskirt which I had used a white primer on, is a "perfect" match to that of the door. Whereas the door cap which I had used a brown primer on, is quite a bit darker than the door. (Door being original Firestorm Red)
    In person, I can guarantee you that I can see absolutely ZERO difference in the paint, regardless of lighting or shade, it is as close to a perfect match you`ll get without going to the actual Firestorm Red itself.
    I hope this helps some people in a bind for a quick fixes if need be.
    Photobucket
  3. #1813
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Drove the piss out of it at Autox. Now my Throw Out Bearing squeaks.
  4. #1814
    Tore my shit apart again
    That is one NICE side mount oil cooler!!!!
  5. The Following User Says Thank You to Hans@GZP For This Useful Post:
  6. #1815
    Pueblo, CO
    adjusted my clutch pedal all the way out and she doesnt creep anymore when i have it in and 2stepin
  7. #1816
    Did you use the Gatecrasher method? It's supposed to be fairly easy to drop if you balance it at the right point and use a hoist.
    I've never pulled the engine or transmission myself but I want to go the transmission so I can take it apart and reseal the case. I have this really annoying slow drop that I want to take care of.
    I had a rear pinion seal go and made a thread about it.
    http://www.3sgto.org/f17/rear-differ...king-6361.html
    Pretty much, I asked Jeff what part he connected to before I started but I just put one side of the chain to the part that holds the linkage and one that holds the cables. I meant to take a pic, I'll do it when I put it back in.
    I'm still getting a little bit. I'll post about it when I get it done and get some results.
    Pueblo, CO
    So, i bled the clutch and it was still creeping a bit. Then adjusted the clutch pedal more and its perfect now. I think my clutch booster diaphragm might be going bad. Its good now, but is there any way to do a booster delete and just do a clutch rod to master cylinder?
  9. #1818
    you'd probably have to run the NA master cylinder and pedal assembly
  10. #1819
    Anybody know what the difference between the AWD slave vs the FWD slave? Cherry hill lists two different ones but in the book they don't show anything different.
  11. #1820
    Never finishes any verified
    Wake Forest, NC
    TT has a longer plunger, not by much, to engage the clutch. I used a FWD on mine for some time until it eventually failed and I replaced it with an Autozone one for like $30.00......
    Was home sick most of today so figured I could at least take pictures of the FMIC install I finished up this past weekend.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  12. The Following User Says Thank You to DrGonzo For This Useful Post:
