Page 5 of 166 FirstFirst ... 345671555105 ... LastLast
Results 41 to 50 of 1658
  1. #41
    Rehosted the files so everyone should be able to DL them now.
  2. #42
    I'm working on a v1.2 which will use the GM 3 bar sensor wired in thru the EGRT. Since there's no EGRT on the 98/99s, that pin on the adaptor harness will need to go to pin 92 on the 98/99 ECU.
    Looking for a volunteer for testing this.
    I would love to, but I need to acquire the hardware first...
  3. #43
    Let me see about getting you a harness adapter. No promises but I'll try.
  4. #44
    www.chromedecu.org verified
    DFW
    *saved for LC1 install instructions
    *ability to log wideband thru pin 93 of the ecu (LC1 and AEM EUGO only for now)
    So I hook up one of my LC1s to pin 93... the fuel tank differential pressure sensor pin.
    Then I set up the WBO2 to output 0-5v or 1.2-3.8v?
    Also I have two LC1s installed... is it real difficult to change another pin to log the other LC1? Then I could seee each bank individually.
    maybe pin 63, 53, or 67
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  5. #45
    DFW
    Does the 2.6 evoscan definition file work with 2.7 or 2.8?
  6. #46
    DFW
    did you get rid of the ignition warmup reatard map? I see you disabled it in the periphs in your 1106 bin. Did you use it for the big maps?
  7. #47
    July 2005
    Arkansas
    It should work. I think I am using a slightly modified version of his def file with 2.7.
    Yes, the warmup map is gone. That bit has to be disabled otherwise the car will run like absolute crap until the water temp is over 160.
    Off topic: Is your car back on the road yet?!
  8. #48
    Try setting it up thru one of the secondary o2 sensors. Just change the formula in EvoScan to match the LC1 in whichever bank you set it up.
    You need the 5v output.
  9. #49
    DFW
    So the stock file will work with 2.7. NIce... does your modification have anything to do with the 2 byte load? or does Gregs file have that in it already?
    and my car is really coming along. Maybe it will be running thisweekend. It still needs the left side painted but at least I will be able to drive it to a paint shop.
  10. #50
    DFW
    wow, 2.7 and 2.8's Data file broke the data.xml file into a bunch of different files. So the changes you made to your data.xml file are all in the the MUTIII mode 2 section right?
