Rehosted the files so everyone should be able to DL them now.
*ability to log wideband thru pin 93 of the ecu (LC1 and AEM EUGO only for now)
So I hook up one of my LC1s to pin 93... the fuel tank differential pressure sensor pin.
Then I set up the WBO2 to output 0-5v or 1.2-3.8v?
Also I have two LC1s installed... is it real difficult to change another pin to log the other LC1? Then I could seee each bank individually.
maybe pin 63, 53, or 67
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
Does the 2.6 evoscan definition file work with 2.7 or 2.8?
did you get rid of the ignition warmup reatard map? I see you disabled it in the periphs in your 1106 bin. Did you use it for the big maps?
It should work. I think I am using a slightly modified version of his def file with 2.7.
Yes, the warmup map is gone. That bit has to be disabled otherwise the car will run like absolute crap until the water temp is over 160.
Off topic: Is your car back on the road yet?!
So the stock file will work with 2.7. NIce... does your modification have anything to do with the 2 byte load? or does Gregs file have that in it already?
and my car is really coming along. Maybe it will be running thisweekend. It still needs the left side painted but at least I will be able to drive it to a paint shop.![]()
wow, 2.7 and 2.8's Data file broke the data.xml file into a bunch of different files. So the changes you made to your data.xml file are all in the the MUTIII mode 2 section right?
