Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: Finally, a new 13T World Record. Details inside
    Decided today was as good as any to use my free hour of tuning I won at Texas Gathering. No hype no crowds just me and 3 other guys counting Steve, the dyno owner.
    I tried to beat the record 472awhp at the TX2k11. Got 471 running out of injectors on following pulls. So I turned fuel pressure up 55 and retuned.
    1st pull - 493awhp @ 19psi
    Tried turning up the boost hit about 24 after about 5600rpm just fell apart.
    Next pull 491 still going a little nuts past 5600rpm.
    Let it cool for about 15 minutes and turned the boost down a little.
    4th pull 501awhp @ 21psi. It still wanted to fall apart at 5600 again but made it through it. Unfortunately my camera man must have got too excited and turned it off before he went to the screen, but I got a dyno sheet and 3 witnesses.
    Medford OR
    Congradulations, pretty stout numbers there. Pretty much exactly what you set out to do... Looks like it might have a little more in it if you can solve the issue limiting you to 21 lbs.
    yea the turbos seem to hit 24 with no problem, but i think I would have to do it on my first pull. I actually want to see if this happens to other people with crx racing front mounts. I've noticed a similar eratic, up and down wave on one other with a crx front mout. Probably not an issue when your driving because you get so much air, but I think it gets heat soaked pretty quick on a dyno. Would like more info on that before I make a conclusion.
    the BOSS of jellow supporter
    May 2005
    Dairyland
    premium gas (93)? meth?
    Congradulations! I know you've been after this for a while now, glad to see it finally come together.
    Quote Originally Posted by a2j View Post
    Now that would be something. Pump gas..... yellow pump. E85
    Williamsport
    Congratz man! That thing sounds good!
    1993 Dodge Stealth RT/TT - Coming Back from the Dead!
    Twin Turbo verified
    Melbourne, Australia
    Nice work. What fuel are you running?
    Edit: didn't refresh before posting... question already answered hahaha.
    Waiting install
    Build Thread
    Nice Mike
    Roo fuckers anonymous verified
    Perth, Australia
    Since when did Stone Cold Steve start tuning 3/S's?
    Scoot
  11. The Following 2 Users Say Thank You to GTO Assassin For This Useful Post:
