This'll be my first real tech/question thread here since abandoning the "other place"...yay for re-motivating!!!
Short backstory:
I've owned my 91 Stealth TT since 99. In 2002, joined the spun bearing club. Over the next year, I rebuilt the bottom end. Didn't touch the heads. Did upgrade with brand spanking new 13G's + supporting mods. Drove it for a while and it was fairly good until the trans took a fair crap a year later. So since 2004 onward, it's been sitting in various stages of meh. Tried to get it all fixed up in '06 in time for my wedding, but the trans was a no go (weird drivetrain stuttering, maybe severe slippage due to the Spec III PP and OEM disc that was swapped in at the time. Stuttering didn't happen until after that swap. Swap was done because wife couldn't deal with 6-puck). Trans has traditional 1/2 grind, 4th/5th is popping out, can't get it into reverse.
Fast forward to 2011. Car has pretty much sat, keeping my garage from floating away since '07 due to reliability and cost of fuel. Only started up less than 10 times in that time period. Lots of blueish white smoke on rev. Now that I'm more financially stable in life, have a decent income, and am sick of seeing Mustangs/Camaro's thinking they're the shit, I figure I will pull the engine after a compression test and refresh.
My questions:
- Car has obviously sat forever. I've never owned a car that sat that long, any "gotchas" I need to worry about?
- Any tips on what I need to look for as I disassemble the trans to investigate the stuttering? Car's a 91 with ~130k, original trans. I'm guessing every single synchro has given up. I have the translated rebuild manual (somewhere), but figure I'd ask first. This will basically be a very long term and slow rebuild of the transaxle as I plan on taking my sweet time and getting it right the first time.
- Pumpkin prolly needs servicing as well...
This is going to be a very extensive resto-mod type deal as it's MY classic car. Essentially, I'm going to take it back to 98% stock (minus the turbo's) and start rebuilding from there.
Any advice is appreciated!
