Current:
2004 ML500 - Mommy Mobile
1995 3000GT VR-4 - lawn gnome
1999 3000GT SL - 7,436 miles
FOR SALE:
And I never said it wasn't safe to run the car with the coolant cap off. If you read the thread, I recommended he take the cap off, start the car up and run it until the fans kick on to check for a coolant leak/air bubble in his system. But if you "GIVE IT A HARD REV" someone is liable to end up in the hospital with 3rd degree burns to the face...
em hit it on the head. having the cap off at idle is fine. having the cap off and going to redline is beyond retarded; it's probably how steve68 got to be the way he is in the first place. so to sum up kiddies....if you don't want to "haz teh dumb", don't do anything steve68 tells you to.
coolant does not shoot out of my radiator fill when revving.
Speaking from experience. I have opened a running cars radiator cap while it was at idle, at operating temp. Knowing what I know, I had three shop towels(red cloth ones) layered and folded to protect my hand from the possible hot coolant.
Funny thing happened. The rags got soaked with hot coolant. Good thing I had a glove too.
You sound like a conspiracy theorist. Fuckin gov't.
Evan, you must have bad headgasket then.
I had a nasty air pocket after changing my pump. All is well now. And I used that kit from graham tool, told me I had no gasses in my coolant.
