As far as i can tell this will work on all models, every Mitsu caliper i have seen here uses that same thread in the caliper, and the OEM prop valve for non-ABS is the same as the NA's use.
If you are interested in it, I will give you a discount on it, and you can be the first NA that i know of to try the kit, and let me know if it needs any changes, but im sure it will work just how it is.
-Austin@STM
