1991 Dodge Stealth R/T Twin Turbo
[B]MODS|ATR Downpipe|ATR Single Shot|DR650's|AEM WB02 Gauge|Ek2mfg Fuel Rail Loop|Polished Fuel Rail|Wrinkle Black Intake Mani|Mirror Red Valve Cover|Ohio Bob Short Throw Shifter|EGR Block Off Plates|Vac Reduction|Evap Delete|Cruise Control Delete|A/C Delete|E2kmfg Poly Mounts|Hotwired Walbro 255lph FP|Tein Coilovers|18x9 Saleen Replicas| 265/35/18 Sumitomo HTR II|New Shortblock|Rebuilt Heads|DSM SMIC|South Bend Stage 4 FE| SOLD
2004 Evo VIII MUSE MotorSports
MODS| Muse UICP| Coilovers| MBC |Muse 02 Dump + Turbo Back Exhaust| GSC S2's |Fidenza Adj Gears| Muse FMIC| FP Black| FP 84mm Intake Pipe| 2.4LR Block| Comp Twin Disc| Shep Tcase| FIC 2150's| MAP Intake Mani|
ooo ooo ooo kits still available?
They are... I just bought one Pete. It's easy to pull everything too! You going to take the wiring and the abandoned lines out? There's probably 30lbs in there.
hmmmm...
still available at introductory price austin?![]()
Just finished the install. Man, getting the old hard lines out is a bear. I had to dremel the last couple out in pieces. The STM kit went in without a problem on my NA. All the fittings matched up, lines were the right lengths, everything just worked. Routing the flex lines in the steering and brake booster areas was a little challenging, just because I wanted it neat and without any spots rubbing. Not completely happy with my work around the steering gear, but oh well. I'll check on the lines in a couple of months to be sure nothing is wearing through.
Thanks, Austin and STM for saving me from a really expensive ABS HU replacement job.
Now, with no ABS HU hooked up, what else could/should I remove? I know about the jumper wire at the control unit under the rear panel, and will be doing that. Can I take anything else out that I don't need/can't use now?
You should be able to just take the whole ABS computer out as there is nothing for it to control anymore, thats how i ran mine. I had that pulled before i even pulled out the ABS pump/lines. Also pull the fuse just to be safe in case any of the wires somehow come in contact with anything they wont short out. If you really wanted to get crazy with it, you can take out the wheel speed sonsors and the sensor rings on the axles.
Glad everything worked out easily, and as far as anything rubbing through you should have an issue with anything, the lines are all coated so there is no bare stainless to rub or cut through anything.
-Austin@STM
And the list goes on...
"If you really wanted to get crazy with it, you can take out the wheel speed sonsors and the sensor rings on the axles."
Will this affect anything else? Is there any point to these if the ABS is removed?
Not to my knowledge, a wiring diagram would tell you for sure if its connected to anything else.
The sensors in the wheels just tell it if one wheel is locked up when the others arent and tells it to engage the ABS.
