Page 12 of 25 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 247
Thread: My full-car build
  1. #111
    Advanced Tech? verified
    Hah! I was just on that sight. Have you looked into the benefits of his windage tray?
    Assessing the Windage Tray Blockage Effect on Aeration in the Oil Sump
    Aeration at the oil pump inlet was measured by X-ray absorption in a production V-6 SI engine motoring at 2000 to 6000 rpm. Within experimental uncertainty, these windage tray changes had no effect on aeration.
    http://dspace.mit.edu/bitstream/handle/1721.1/38713/166145859.pdf
    Then a windage tray aeration reduction study was performed. Three alternative tray designs were tested. Results showed the design changes to have no significant affect on the aeration level.
  2. The Following 6 Users Say Thank You to i3igpete For This Useful Post:
  3. #112
    Thanks, I'll order a new OEM harmonic balancer instead.
    I ordered the replacement face for my UR lightweight flywheel earlier today. So now ill have everything ready for balancing etc.
    -Benn
    Master Elite KIA Technician
    Follow my build thread here
  4. #113
    One fix at a time verified
    Kansas
    There was some other testing on the windage tray and crank scrapers but I think it may have been on 3STech. I know it has been awhile since I read about it because I thought they would help out, but neither ended up making any improvements. Feel free to try and dig up the info. I know some of our members tested it out.
  5. #114
    More parts.. Belts, OEM balancer, oil pickup tube, and new flywheel face
  6. #115
    HKS DLI, Ninja Performance big bore lifters, 2nd Walbro 450lph e85 pump, single solid lifter, Magnecor 10mm plug wires (vs 8mm MSDs in first picture)
  7. #116
    Ordering a precision 6870 and quick spool valve tomorrow morning!!
  8. #117
    Kansas
    It will be interesting to see how that turbo performs since we have to run longer manifolds in a single turbo setup. It should work well with the QSV although you won't get any benefit over a 6766 unless you plan to push the turbo near its limits.
  9. #118
    Yea I figured I would be the first one to run it. I was really looking at a gtx4297/02 before this came out. I'm going to try to run it to its max so we will see how it does. I'm going to run it with just the qsv first to see where spool is. If its a little bit too laggy, ill get a tiny bit of spray to help it out. I plan on running e85 as well so it should help me out some there too.
  10. #119
    Billet shift forks, new bearings, and seals
    Turbo and qsv should be here tomorrow
  11. #120
    Turbo porn. Gen 2 PTE 6870 dual ball bearing polished HP cover 1.0 a/r turbine housing and quick spool valve. All from sound performance. Excellent customer service and fast shipping.
    6870 vs 60-1 "gt30" vs dr500
