Some of you guys may have read my thread when I first purchased this car, but if not you'll have to dig it up on the "other" site if you're interested and you feel like reading some on how I brought my VR4 back to life.
Here is a current mod list of everything on the car right now..
Engine:
JDM 6G74
Merkel 4340 billet 6g75 3.7L stroker crank
Custom Ross racing pistons
Billet Oliver/Pampena custom rods
Pampena HD wrist pins
ARP CA625+ main studs
A1 head studs
Ninja Performance big bore lifters
IPS 5-axis CNC ported "Race" heads with +2mm oversized valves
Merkel head lift fix
Brian Crowler springs and titanium retainers
Dynamic Racing 274 cams
BC/Pampena adjustable cam gears
OEM gasket set
OEM water pump
OEM oil pump with Italo Graso billet gears
OEM timing belt
Ninja Performance solid timing tensioner kit
Setrab/Maximal Performance oil cooler
Custom crankcase ventilation
Solid engine mounts
3SX Single Pass Radiator
Derale H.O. fans
Radium High Pressure Radiator cap
Mugen S2000/NSX thermostat
HKS oil cap
New 1G Cam Crank angle sensor
OEM Knock sensor
OEM Coolant Temp sensor
Custom singe turbo manifold
Custom 4" downpipe
Precision 7675 DBB 1.15 a/r turbo (titanium blanket)
Tial MVR 44mm
Brian Carter made intake
BBK dbw 90mm throttle body
Custom ETS 5" 3/S fitment FMIC
Custom 3.5" intercooler piping
Custom FMIC ducting
TiAL BOV
IPS/HKS carbon ti 4" titanium exhaust
Fuel:
Pampena fuel rails
Custom RSI ID2000cc injectors
Fuelab FPR
Fuelab filter
3SX custom sending unit
Fuelab Prodigy 42402
Ignition/Electronics:
Rvenge coil on plug conversion
ProEFI w/ flexfuel
HKS Type 0 Turbo Timer
Old school black face GReddy 60mm gauges -
-3 bar boost PWH
-oil pressure PWH
-temp (water) PWH
-oil temp PWH
-52mm fuel pressure
AEM analog wideband gauge
HKS twin power DLI
Drivetrain:
US spec 6 speed
OS Giken R3C Triple Clutch
New OEM bearings
New OEM seals
New OEM syncros
New oem fork and ball
Bellhousing brace
Custom midcase brace
Quaife Front LSD
Supercar Engineering Torsen center differential
Supercar Engineering billet shift forks
Broomfield Racing billet endcase
Torque solutions shift cable bushings
Torque solutions shifter base bushings
Blackline Weighted ARC Titanium Shift Knob Replica
Ohiospyderman's short throw shifter
STM master to slave SS clutch line
Oem slave cylinder
Pampena solid rear differential bushings
PST HD Race 1 piece carbon fiber driveshaft
Brakes and suspension:
OEM ABS delete
Evo x calipers
Braided SS Brake lines
Hawk HPS brake pads
Girodisc 2 piece rotors
KSport coilovers
PRM rear adjustable upper control arms
Volk lower control arms
Volk aws delete
Refurb rear subframe
Solid subframe bushings (not installed)
New OEM front hub assemblies
Addco rear sway bar
Work Emotion CR 2 piece wheels wrapped in R888's
Exterior:
99 Front bumper
99 Turn signals
99 Sail panels
99 Rear garnish
APR GTC 500 3S specific wing
JDM tail lights
Interior/Miscellaneous:
Personal Neo Grinta steering wheel
Corbeau 5-point harnesses
Corbeau FX1 Pro seats on Corbeau sliders
Porno red carpet
Dynomat from rear seat bottom to rear of car
Battery relocate to rear
Trunk plastics/carpet/fiberboard removed
Active Aero delete
Cruise control delete
Rear wiper delete
Clutch booster delete
Power antenna swapped for flexible shorter rubber one
Vacuum reduction
Antigravity 5lb battery
