Page 686 of 892 FirstFirst ... 186586636676684685686687688696736786 ... LastLast
Results 6,851 to 6,860 of 8916
  1. #6851
    Mad JDM Tite
    STL
    Dropped it off at the body shop - finally fixing the aftermath of my wheel incident at NG13 along with damage on the rear bumper from the moron who backed into me and just drove off without leaving a note.
  2. #6852
    Oct 2011
    Sundsvall, Sweden
    I have that puller too, k-m something, got it from ebay for like $25. It works really well.
    FYI its a dt-47865
    Kent Moore DT 47865 6L50 6L80 6L90 Transmission Bearing Remover | eBay
    turn the legs around and you can grip the bearing race. I found one for 20-30 once. Its made for a slide hammer.
    Thanks!
    I'm ordering one of those right away.
  3. #6853
    Sep 2012
    Decatur, TN
    Just make sure you position the legs very carefully under the edge of the races and it's good and tight. If you don't get a solid seat under there, you can chip the race. A helper to hold the cases steady while you use the slide hammer is a nice addition, but can be done without.
  4. #6854
    Quote Originally Posted by 95gto View Post
    Was Jason involved in this bumper incident???
  5. #6855
    Mar 2013
    SL owner since Jan 2010. VR4 owner since Sep 2012
    Riverside, Cali
    Replaced slave cylinder on the SL :P.
    1991 Monza Red VR4- Weekend ride: Tanabe Super Medallion Hyper exhaust, 0.8 bar WGs, Turbosmart MBC (@1 bar), 3SX turbo pre-pipes, Straight pipe, Greddy Type RS BOV, Godspeed FMIC w/ PPE pipes, Stillin DP, HKS duel filters, RPS stage 2 clutch, 3sx SS clutch line, Custom oil catch can w/ braided lines, Krank vents, Ohhnoo's fuel loop, HW fuel pump, PC'd 2G brake swap w/3sx SS lines, Hawk pads, and Stop Tech rotors; Various deletes, PC'd/polished engine stuff, Koyo rad, Greddy coolant cap, DBest custom oil cap, Pit Road M front strut bar, PRM plug cover, PRM tailights, PRM CF Falcon hood and PRM shift knob, Morgan Motorsports splitter, 19x8.5 +27/19x9.5 +24 Volk GT-Cs wrapped Nitto NT555s, 99' bumper conversion, 99' sail panels, 2G side skirts, Retrofitted 5G Celica mirrors, Retro Spec side splitters, RS rain guards, and RS rear window visor, factory GTO light up visors, Custom fit Top Secret style diffuser for 350z, Robo mod w/halos, 3G rear garnish, Momo steering wheel, Tein Street Flex coilovers, 3SX control arms, Apexi turbo timer, Apexi mechanical boost gauge, Zoom Engineering Penta rear view mirror, Veilside navigators foot rest, Pioneer HU
  6. #6856
    Mad JDM Tite
    STL
    This moron happened to work for the same company as me, just a different division. What really pissed me off is that I had to stay late on a Friday for a conference call so this happened after the normal time I would have left for home. Not to mention that when my car was hit, it was hit hard enough to set off the alarm so it's not like the person that did it didn't know.
  7. #6857
    Sep 2012
    Decatur, TN
    So traded my flashable plus some cash for another AWD trans that I will most likely sell/part out (but may run it until Chris is done with my trans,) another set of rear axles, another FMIC kit (with a core that's something around 3-4" thick), Tial VTA blow off valve, and a home made TT manifold (vaguely log style) set up with knock off GT28R (or GT28RS) turbos. Cosmetically not a great looker, and highly unlikely it will replace my 14Bs (since they're already set for open dump and I don't feel like hacking off and rewelding flanges to utilize knock off turbos that may or may not outperform.) At any rate though, should more than get my money back out of the deal.
    Still waiting for the undercoating to get here, and haven't had time to get back out under the car and scrape more shit off of the underside. Rear subframe is mostly ready for coating, front control arms need the ball joints taken back out (without damage) so that I can clean them and coat them. More stuff needs to come out of the engine bay to complete it as well, and I need to get a new firewall insulation pad of some kind (or make one. Fun shit.
  8. #6858
    August 2010
    Chicago
    last night...16 degrees timing advance(thought it was 17)...e85. I'm happy.
    34XXlbs..
  9. #6859
    August 2010
    Chicago
    comparison between EVO maf full boost/spool vs MAF translator(red line). I think its showing 2 lines for boost because i have 2 map sensors(blue lines)
    uncorrected numbers
  10. #6860
    Sep 2012
    Decatur, TN
    Did you change anything else in the tune aside from swapping the MAF and adjusting tables for it?
    Speed density or blow thru? Pipes on the turbos? Just curious what all changes you've made between them for a pretty substantial decrease in spool up time.
