Page 685 of 892 FirstFirst ... 185585635675683684685686687695735785 ... LastLast
Results 6,841 to 6,850 of 8916
  1. #6841
    Quote Originally Posted by Unlogic View Post
    What type of puller is that?
    Seems to be a good one for pulling the bearing races.
    I have that puller too, k-m something, got it from ebay for like $25. It works really well.
    FYI its a dt-47865
    http://www.ebay.com/itm/KENT-MOORE-D..._Tools&vxp=mtr
    turn the legs around and you can grip the bearing race. I found one for 20-30 once. Its made for a slide hammer.
  2. The Following User Says Thank You to Chris@Rvengeperformance For This Useful Post:
  3. #6842
    August 2010
    Chicago
    would have been a nice one but came out blurry...
    34XXlbs..
  4. #6843
    I don't bite
    Southern IN
    What did you do today to your 3/S?
    Nomie, try bending down with camera almost to the ground for some of those shots.
    Car looks badass...!!
  5. #6844
    I don't bite
    Southern IN
    Bought FIC2150's for the 4g.
  6. #6845
    Need to stabilize the camera. At least hold it against a wall or something, that will help cut down on the shake.
  7. #6846
    Twin Turbo verified
    Melbourne, Australia
    Bought a buffer to fix my paint. Coming up pretty good. One of my panels was faded almost to white. Used some cutting compound and now it's back to normal. Will start the polishing process tomorrow.
    Waiting install
    Build Thread
  8. #6847
    Sep 2012
    Decatur, TN
    Quote Originally Posted by sublime_whatigo View Post
    Kent Moore DT-47865 is the part number
    FYI its a dt-47865
    Kent Moore DT 47865 6L50 6L80 6L90 Transmission Bearing Remover | eBay
    Thank you gents. Unfortunately this one has been used enough that pretty much all of the manufacturer markings have long since been worn out to illegibility.
    Back home from Ninja's now (boo ) but going to try to get back out there maybe over winter break from school, or spring break. Lots more to learn and help with. At this point we've got it down from about 8 cars needing work done to 5, and one of them is finally just about down to the "just a tune" stage after fixing a myriad of other problems.
    Snagged some Ninja camber arms for the ass end of the car, saw a new project that's coming down the pipe (and is very nice) that should be released in 2-3 weeks most likely (once enough stock has arrived) and reignited my drive to get this car done properly. New fasteners for pretty much everything on the underside of the car are in order, and I will be ordering 2 quarts of Masterseries silver under coating as well as 2 quarts of the AG111 top coat. Given each quart does about 100sq ft as a single coat, and I measured the underside of the car at around 75-80sq ft, plus doing the subframes, control arms, engine bay, etc. I'm anticipating needing about 4 quarts of the silver undercoat and 2 quarts of the AG111 (as a single coat should be enough.) 2 quarts of undercoat would at least give me enough to do the underside of the car with 2 coats, and then use up the remainder in the cans on the rear subframe I believe. Unfortunately without a lift, I can't really spray the product (since the car is too low to the ground even on stands) so I will have to brush it on.
  9. #6848
    August 2010
    Chicago
    I've got a tripod...will try to utilize it next time out
  10. #6849
    Quote Originally Posted by NOMIEZVR4 View Post
    What camera did you get?
  11. #6850
    August 2010
    Chicago
    Bill its a Canon Rebel XSi...its my brothers...but same difference. Its mine...
