Page 786 of 892 FirstFirst ... 286686736776784785786787788796836886 ... LastLast
Results 7,851 to 7,860 of 8916
  1. #7851
    dick...
  2. #7852
    Madison Heights, Mi
    drilled/tapped all the bolts that I broke removing the bumper, side skirt and fender.
  3. #7853
    wanderlust
    Chi-town/ATL
    IAC
    Next brakes
    1991 Jamaican Blue 3000gt VR4 || Maddog Performance Engineering|| Roadracers go in deeper and come out harder!
  4. #7854
    dick...
    If you want it let me know.
  5. #7855
    Never finishes any verified
    Wake Forest, NC
    If he wants your "Dick"..... LMAO!!!
    Finally figured out that awful noise coming from the front of the car.... After pulling the accessory belt assembly apart like 20 times replacing all pulleys, AC compressor, Belt, Etc. I decided to check driveline and found the drivers intermediate shaft bearing was toast! Bearing was grinding had about an inch of up/down shaft play and the dust guards where scraping the mount which makes the same sound the AC compressor does when the clutch is failing.....
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  6. #7856
    Spent my afternoon / evening playing with cardboard, working with multiple templates to get one just right....This is the final product:
    Now to take it to Line-X.
  7. #7857
    Wake Forest, NC
    Are you just going to Line-x the whole car someday.....
  8. #7858
    Somebody already did that.
  9. #7859
    Dec 2014
    Clear Lake / Seabrook
    Ouch! I had to spot weld an e- brake bracket. 2 hrs to fix the welder, 5 min to weld the bracket.
  10. #7860
    Member
    Chilliwack BC
    IIRC that ball bearing is a 'loose fit' bearing- I think due to the close proximity to the downpipe. The tolerance of that particular bearing would be denoted in the # stamped on it, & I wouldn't stray from that fit if you cant get the factory one.
