Mark, with a new crush washer the tranny drain plug should not be leaking. Are you positive it is not leaking from the case seal and running down?
On the PS system, if you haven't changed out all the rubber hoses you should plan on doing it. Those hoses just get hard over time and don't seal well on the hardlines and reservois.
