A large wad of paper towel.
Ordered a datalogger kit
Ok good ideas. I was at work and contemplated wrapping a shop rag around my sticker scraper but didnt want to accidentally slice my dash.
i got one of these at the 99 cent store for my windshield
Wrapped up the Water Pump change and new timing belt installation.....so easy yet such a pain in my @$$. NOW I can get back on track with the engine and transmission mating and drop that bad boy in. Having nightmares about it BUT...I will manage.
Installed an amazon.com ptu and it does not work. Do not buy this ptu. The car idles and drives fine but when you drive it, the tach moves very jerky like it gets a signal every half a second. I put the stock one back in and no tach problems. So much for preventative maintenance today. Other than that I adjusted my base idle. 700rpm solid. 25psi oil pressure. Also hit 14psi on 9bs, which is very boring.
Stared doing an integrated install of my speed meter, turbo timer, and boost controller into the center vents. I've never used them as they dry my eyes out, so I figured what better place?
I just cant decide if I should put the boost controller in the middle, or keep it on the bottom?
