Page 582 of 892 FirstFirst ... 82482532572580581582583584592632682 ... LastLast
Results 5,811 to 5,820 of 8916
  1. #5811
    I have solved my tuning issue! The latencies are incorrect from DW..
  2. #5812
    pretty sure I have posted many times you can't use the latencies provided by injector manufactures and expect them to work on the flash ecu.
  3. #5813
    Last April actually. Got it with a broken timing belt so I've been slowly getting everything needed for the build. And now I have the space and time to work on it. Hope to have it up and running come spring
    When did you get a spyder?
    "Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
    ----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
  4. #5814
    Feb 2014
    2002 and 2014
    Hamilton, Ontario, Canada
    Cleared two feet of snow off of the '92 after a freak snow storm that came out of nowhere! Placed an order with 3sx for some much needed goodies. Also, tracked down a new oil pan for the '91 TT.
    Sent from my Nexus S
  5. #5815
    wheatfield, IN
    got my mirrors all wrapped
    Sent from my DROID RAZR using Tapatalk
  6. #5816
    Feb 2014
    2002 and 2014
    Quote Originally Posted by dpartinvr4 View Post
    What did you wrap them with? Automotive vinyl?
  7. #5817
    Yes, so much data to absorb, so little grey matter...
  8. #5818
    I don't bite
    Southern IN
    What did you do today to your 3/S?
    Downpipe mounted. Exhaust soooo close to being complete. Just a little tweaking to center in bumper opening and it will be finished. Only two 45* bends. 4" all the way
    Axle is supposed to arrive tomorrow. Need to wire shiftbox and it will be driveable!
  9. #5819
    Wait until you downshift into first with the car moving.
  10. #5820
    I don't bite
    Southern IN
    Head through windshield downshift?
