This is the TT intake runner internal design. Notice there's a V-groove pent roof.
This is the N/A runner design. Notice the ceiling is smooth as compared with the TT design.
Interesting, never noticed that.
probably casting mold since it's a one piece vs na two piece runners.
I was thinking they were vortex generators or something to promote swirl? They align with the valve divider in the heads so hrmm. I wonder if all versions of TT intake manifold have that design? What does your runner look like? Also, what's the total length on it? You mentioned some hood interference? Did you cut down a TT mani or use the N/A lower?
Bill, do you have a pent roof on your TT runners?
All the TT plenums I've seen have that "V".
Does anyone even make a real manifold, that bolts to the cylinder heads, and doesn't use the stock lower runners?
Would be difficult to bolt the rear cylinders down as it takes 2 bolts per cylinder, and would have to bolt through the runners.
