Page 549 of 892 FirstFirst ... 49449499539547548549550551559599649 ... LastLast
Results 5,481 to 5,490 of 8916
  1. #5481
    I don't bite
    Southern IN
    Did some tuning on AEM. Idle is damn good. Trimmed rear bank to even out o2s. Gave it a lot more timing control at idle to hold idle steady instead of relying too much on IAC. Sometimes fueling is off depending on intake/underhood temps so still need to figure out how to tackle that, but it still holds idle pretty steady.
    Also did a 3rd gear knock cal run to 7400rpm. Little cleanup to do on fueling and then will try +1,-3 on cam gears (which will then throw off my fuel map again)
    Chasing some wild bank to bank fluctuations in vac at 14-1700 (rear way lean, front good) 2500-2800 (rear way lean, front good) and 3400-3700 rpms (front lean, rear good). Added a bunch of timing and it pulls much cleaner, but still have the same swings.
  2. #5482
    Not much yet!
    Sent from the Man Cave!
  3. #5483
    Nope, still nothin!
  4. #5484
    Nope, still nothin!
    That's nothing.
  5. #5485
    Wrench Monkey Not Verified
    Rochester, NY
    Quote Originally Posted by donniekak View Post
    That's nothing.
    Uhh I think you have a ground short in your outside temp circuit.
  6. #5486
    Quote Originally Posted by TwIzTeD_3kGt View Post
    No, I live in a desert. Our record temp here is 122*
  7. #5487
    Rochester, NY
    Can you even go outside for more than a couple minutes in that?
  8. #5488
    122* desert heat isn't as bad as 90* with 100% humidity.
  9. #5489
    Whoever told you that was lying.
    I moved back to Ohio for a year, and worked outside every day removing trees from underneath 500kv transmission lines. When it was 97* and humid, I was laughing at everyone who was complaining about the heat. I was wet, but not really hot.
    Picture this. The difference between 60* and 90* is the same as the difference between 90* and 120*.
    115* and higher is truly a different level. Working outside in Arizona is very different. If I set a ratchet down in the sun for 2 minutes, it's impossible to hold in your hand. A breeze feels like a hair dryer. Any public business in Arizona must provide water for anyone who asks.
    I paved roads in Arizona for a couple years, and have never experienced anything close to that level of heat in my life. I now consider anything under 110* a walk in the park.
  10. The Following User Says Thank You to donniekak For This Useful Post:
  11. #5490
    I lived in Vegas for 4 years. I will take 120 desert heat over 90* and 100% humidity ANY day.
    It was 92 with high humidity the other day and it was fucking miserable. I used to play outside in the Vegas heat without breaking a sweat.
