Page 28 of 135 FirstFirst ... 1826272829303878128 ... LastLast
Results 271 to 280 of 1341
Thread: CoopKill's Mistress Makeover Thread [Pic Heavy]
  1. #271
  2. #272
    Medford OR
    Looks like it's all there... Nothing to worry about.
  3. The Following User Says Thank You to RealMcCoy For This Useful Post:
  4. #273
    Progress! Nathan made the epic trip down to help out! Just about ready to go in. Just a few things to button up, and should have
    the clutch, and trans on tomorrow. Got the meth lines all routed, and in place. All the water lines are handled. Need to get 2 cap bolts tomorrow for the rear fuel rail, and will be able to get the intake back on. Will prolly wait till next weekend to get it in the bay. I need to do some prep in there first. (Fuel, egr delete, some clutter cleanup).
  5. #274
    1993 rt/tt Not Verified
    wa state
    Nice job sir, maybe next weekend will be warmer
  6. #275
    Sexy sexy
    Post via Tapatalk
  7. #276
    Anyone have an idea where this goes?
    Or these?
    Sent from the Man Cave!
  8. #277
    Medford OR
    #1: bracket from rear motor mount to rear precat.
    #2&3: tin shields on the front of the heads under the timing cover.
    #4: rear turbo oil line bracket
    Last edited by RealMcCoy; 05-26-2013 at 05:41 PM. Reason: apparent temporary blindness
  9. #278
    Man vs 3/S verified
    Kingston, WA
    Thanks. Got them where they belong, now.
    From the phone.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  10. #279
    Well it is in! Thanks Larry for the help with the brackets. I should of done a little better at documenting parts once the engine was out. I was in strip, chuck, and in the truck to the machine shop mode.
    Pics!
    Clutch on.
    Nathan attacking the clutch line to replace.
    Trans on, after pulling off twice! Brandon stopped by to pick up the 94 chromies, and says "Uh guys? What about the flywheel plate sittin on the floor over here?" He was quickly directed to leave the premises before rage ensued. Then while looking for a tool I constantly set down, and never can find again, I seen the directions from the clutch box. It appears they are to be installed a certain way on the flywheel. So off with the trans again!!!
    It was on backwards, so worth pulling it of once again.
    Up, up, and away.
    In with the ps, and ac installed. Much more work ahead!
  11. #280
    JNS Engineering verified
    San Jose, CA
    Nice work! I can't wait to get to that point.
