Also.. to post an interesting story... the car wouldn't start yesterday, and I couldn't for the life of me figure out why. I checked the cylinder compression on the front head and each cylinder read 150PSI completely cold. Then I decided I'd check for spark, so I removed all of the front cylinder spark plugs and had my dad turn the car over... two seconds after cranking, the engine fired up with three cylinders o_O Replaced the spark plugs, fired it up again. Problem solved??
It was interesting to me that it could even run on three cylinders - let alone the fact that the problem seemingly magically fixed itself :-P
