Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 93
Thread: Got my turbo kit today..
  1. #41
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Just to be an echo, I when I bought my AN return kit I was told should never go smaller then -8an
  2. #42
    Banned J. Fast's Avatar
    Congrats on getting it fired! Such a nice feeling when they've been sitting for long periods of time.
  3. #43
    Nope, it smelled more like 6:1. :P
  4. #44
    Your return lines are what, -6? They look too small based on years of watching these sort of build threads and subsequent problems with burning oil, blowing turbos, etc. I use -4 feeds as well (I used banjo fittings at the ports on the oil pump/filter housing, so my -4 lines probably flow less than yours), but my returns are like -10, with a slight down hill path to the pan. Never had an issue... But I bet you will.
    Nah, those are -10AN lines.
  5. #45
    subbd.
  6. #46
    Ann Arbor, MI
    Quote Originally Posted by box View Post
    Looking pretty so far.
    With the front oil feed line, looks like you're loosing a lot of height here
    Make something like this, weld an AN fitting on where the cross is and you can get yourself an extra inch of fall without modifying the sump or the engine mount.
    These are journal bearing turbos right?
    Someone may have already mentioned this.
    Looks like your front and rear drain lines are reversed. Looks like the rear drain line should be on the front turbo and vice versa. The "L" shaped bend is pointing the wrong direction.
  7. #47
    Nah, the issue was that the rear turbo just needed to be slightly clocked. The rear line is way shorter than the front, so that wasn't the issue I ran into a problem a couple weeks ago, however, that pulled the car off the road... after swapping out the rear head, I got it fired back up yesterday :] Hoping to have it all put back together today, including FMIC installed - then I'll have some videos
  8. #48
    Just a little update here....
    Getting pretty damn close....
  9. #49
    oct.2007...
    Cleveland, Ohio, United States
    Can't wait to see your results with the turbo kit!
  10. #50
    Sep 2011
    that floor jack must be bitch to drag. lol
