Page 16 of 20 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 195
Thread: Now Another Problem.....
  1. #151
    OK, found the answer ( I think. cross your fingers, the motor is warming up now.). Now my next issue is the idle. I adjusted the TPS, and it's still idling at about 1100. Any other ways to reduce the idle?? The idle screw is "turned down" as low as it will go.
  2. #152
    And the test was a no go. The fan never turned on. I turned off the motor at 185 degrees. And just for shits and giggles, I measured the relays at pins 5. There is no longer power to them, which is probably the issue. I believe the walkthrough for the red and green wire, but that just leaves the issue of power to the damned relays and fans. Anyone got any input on this one?
  3. #153
    Canaan NH
    Not sure. Keep in mind though that the link to 3si was using a 94 radiator I believe.
    You may have a vacuum leak causing the high idle.
  4. #154
    I'm pretty sure I do have a vacuum leak. I can hear air whistling at the TB, but I can't find the leak. I can deal with the slightly elevated idle for now, the biggest thing is the radiator. Are you SURE there should be power at pin 3 in the relays?? Doesn't that prohibit the flow of power through the circuit from pin 1 to pin 3?
    Edit: OK, WTF. Now there is power to pin 5. Regardless, shouldn't there be power to only pins 1 and 5, since pins 4 and 3 head to ground??
  5. #155
    Canaan NH
    Pin 3 should have power to it ONLY if the relay is plugged in and the radiator switches are not closed. But thats for a 91 relay setup. Not sure what you are using ?
  6. #156
    It's a 94 box. But the principal is the same. Below I posted the 94 schematic. Then the issue is that there is power being supplied to pin 3 of the relays, but from where?
  7. #157
    Canaan NH
    Ok, here is my take on this.
    Pin 3 of the low relay needs to go to pin 3 of the radiater, currently would go to pin 6 on the to the ECU on the old harness.
    Pin 4 of the low relay needs to go to pin 4 of the radiator, on old harness it would go to a resistor.
    Pin 1 of the hi and low relays should have 12v.
    Pin 3 of the low relay should go to pin 6 of the radiator, on the old harness it went to pin 53 of the ECU.
    Ground pin 1 of the radiator. Now if you have power to one side of the radiator fans this should work. Test would be jumping pins 4 and 5 of either relay.
  8. #158
    Based on what you're saying, is electricity flowing from the top to bottom of the page, or from the bottom to the top? And I'm thoroughly confused. It goes to pin 53 of the ECU now. The diagram 2 posts up is the 94 model.
  9. #159
    Canaan NH
    You have 91 ECU correct ? It doesnt control the grounds for the fan, the radiator now does that. Basically in the 94 the ECU does the work of the radiator plug on the 91 diagram.
  10. #160
    Gotcha, so it's independent of the ECU. Another oddity, since I just love coming up with more problems. On the LO relay, the pin with the lower voltage, due to the resistor, is pin 1....?? Pins 3 and 5 both have the full 12V. Does that sound right to you, since I can't see how the resistor would even be connected to pin 1.
    Edit: But following that walkthrough from that link I posted earlier, the wires for the temp switches I ran into the body, and tapped them into lines that run directly into the ECU.
