Page 15 of 20 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 195
Thread: Now Another Problem.....
  1. #141
    Canaan NH
    Pin 5's of the high low relays in the main fuse box on the passanger side correct ? They should not have power on them unless the fan motor can send its power to the ungrounded ground wire. That wire should be the switched ground wire for the fan. If this is the pin 5 on the correct relays then touch it off ground and the fan should spin.
  2. #142
    OK, so on the relays (hi and lo) in the diagram, it looks like pin 1 on both of them is fed from the same source, correct?? Or is it just the low?? Aside from the voltage that is correctly (supposedly) feeding pins 5, how many other power supplies are there into this circuit? One or two more?
  3. #143
    Which they don't. Which means either pin 5 is fed wrong, or there is no other power getting to the fans, right?
    Edit: Why, if I were to jump pins 4 and 5 on the Lo relay, should the fan not start up?? Isn't that the same as bypassing the coil in the relay that's normally fed by pins 1 and 3?
  4. #144
    Check out this link. His pics for the radiators are further down the page since they are gone from the original post. What do you think of that?? Those are the exact wires that I'm having an issue with. But I didn't think they were grounded. I'm going to have to go trace the ground in the plug I think, since both grounds are in the plug.....??
    http://www.3si.org/forum/f53/1g-harness-2g-body-274771/
  5. #145
    Canaan NH
    This explains why I am stumped.
    3. Radiator fans
    On the 1g cars, the fans are controlled by 2 switches mounted in the radiator, on 2g cars they are controlled through the ecu. This is how i wired them without modification to the fan harnesses, and keeping the 2g fans with a 1g tt radiator.......Take the black wire from each switch, tie them together, and attach a grounding lug to them. Next take the other wire from each switch and run them into the passenger compartment to connector C-29 near the blower motor. tie these wires into pins 3 & 11 of C-29 (pin 3 high, pin 11 low). Heres a couple pictures of how i did it. I chose to use another weather pack connector from NAPA so the connection can be unplugged to remove the radiator without cutting any wires.
    I have been looking at a 91 schematic all this time. Still confused though. If you dont fix it before I get home I will pull up schematics for the 94 and compare then walk you through it.
  6. #146
    I'm writing a paper right now that's due in 3 hours, but I hope to have it finished sooner so I can run those wires real quick. I will still need your help. I am thoroughly confused now about the other 4 wires, the ones that DON'T connect to C-29. Two are black, which I suspect I am to ground, but that leaves 4 pins for the 2 blue wires on the radiator side.
  7. #147
    OK, paper is done. Off to go ground the black wires and run the wires to C-29. I'll let you know how it turns out.
  8. #148
    And I got all but the two wires for C-29 in. I have to go to class now, but I'll be back about 9. I'll post then to let you know I'm back, and then I'll go splice in those wires, see what happens.
  9. #149
    I'm home, going to go splice in those two wires. I'll let you know how it goes.
  10. #150
    Heh, I can't go any further. Mainly because- which wire is HI and which LO??? Can't find any indication which goes to which pin.
