Only if something is wired wrong.
What could be wired wrong? I only made 2 SWAG wire splices. At the MFI and at the fuse box under the hood (connector A67).
Maybe the wire that is supposed to be supplying power to the fuel pump from the MFI relay is actually tied to the wire that SHOULD be coming from the ECU to activate the coil in the MFI relay. Does that make sense ?
Yes it does. And that actually was it. I wound up going through my diagrams, discovered that the MFI SWAG had pins 4 and 8 reversed. So I respliced them, and made same progress. The motor turns over, and starts on its own. It keeps itself going for about 3 seconds, until I hear the MFI click, and then it dies. Thoughts??
Pull the ECU and look for leaky capacitors. Thats usually the problem when the MFI drops out.
That's what I thought. I pulled the ECU, and used my known good NA ECU. I know it won't run correctly, but it should at least run, and not cut out after a few seconds, right?? Anyways, it did the exact same thing with the other ECU in. No change.
Check all fuses. For some reason the ECU thinks you shut the ignition off. Also verifiy the grounds to to the ECU are all good. One other test is to disconnect the MAF and try to start, sometimes a bad MAF can cause problems like this.
You might also try unplugging the IAC and see if it stays running. A shorted IAC might shut it down when it kicks down from high idle.
Already tried the MAF. No change. Between the generations, the grounds from the MFI, wiring harness and one more from another source I'm not sure, were localized to one ground source. I was missing a ground in that localized point. I'm guessing it may be the ECU?? Maybe not?? There was a ground sticking out of the harness by the ECU plugs, but I'm not sure if that went to the ECU. Can you explain what grounds go to where on the ECU?? I have a developing theory, that maybe because the wires were spliced incorrectly, could that have ruined the MFI?? Are you talking fuses inside or outside?
The ground sticking out of the harness is likely a shield for the knock sensor wire, it goes nowhere. There is a diode in the MFI that could have blown from the wiring but I am not sure it could cause your problem. I believe the MFI is doing its functions properly.
If it was me this is the hillbilly test I would do. Disconnect the MFI, bend the little tabs on its metal cover and remove the cover. Plug it back in. You now can visually see the contacts for two relays. One powers the fuel pump, the other the ECU. Start the car while observing what the relays are doing. When the car dies, try to start again while holding one or both of the relays closed. In theory it should remain running. Now you need to figure out where the relay is losing its power or ground and why.
