Originally Posted by
CoreyB
Ok, here is my take on this.
Pin 3 of the low relay needs to go to pin 3 of the radiater, currently would go to pin 6 on the to the ECU on the old harness.
Pin 4 of the low relay needs to go to pin 4 of the radiator, on old harness it would go to a resistor.
Pin 1 of the hi and low relays should have 12v.
Pin 3 of the low relay should go to pin 6 of the radiator, on the old harness it went to pin 53 of the ECU.
Ground pin 1 of the radiator. Now if you have power to one side of the radiator fans this should work. Test would be jumping pins 4 and 5 of either relay.
