Page 88 of 154 FirstFirst ... 3878868788899098138 ... LastLast
Results 871 to 880 of 1538
  1. #871
    One fix at a time verified
    Kansas
    Antero, I was just wondering how soon Adam will be done with testing. I have no problem testing the three different cable designs and will pay for them since I will know in a hurry if they work. Just logging as few as 2-3 items I still have problems above 3k rpms. Grounds are all good too. Maybe I should ask Adam how close he is since he's cloning my ecu this weekend. I need to get a noise cancelling OBDII filter cable badly so I can datalog boost; otherwise, I have to buy another EBC or wait to wire in a boost sensor to the flashed ECU because I need to sort some issues out on my car that have been plaguing me the past 5 months. I ordered a Hallman Pro MBC to use instead since I'm pretty sure the LCD BC won't let me run a steady 25+ psi until it gets more features outside of a duty cycle based control. I tried setting up the duty cycle vs airflow but it won't work when the LCD BC doesn't get clean enough OBDII readings. Maybe once I fix that and do a 2-byte airflow vs duty cycle it will be better outside of temperature changes. For now I'm abandoning it.
  2. #872
    Quote Originally Posted by FeaRpb View Post
    Im not sure if this is a feature or not, but is there a low boost and high boost setting? If not, how hard would it be to make one?
    When the "Auxiliary input" sees ground, it will activate. You can use this to run low boost mode. To wire it up, grab a switch and put one wire to ground, and the other lead to the Aux. input.
  3. #873
    Last time I asked Adam, he did not receive it yet (slow ground shipping). That's why he was unable to provide feedback on the noise filter designs. It's been a while now, so I haven't asked him if he's received it yet or not.
    I have parts to build a noise filter design #3, but none of the others. I think #3 is the best so that's why I have accumulated parts for it. So if you want try that, send me a private message.
  4. #874
    Firmware 3.03 is available. http://lcdbc.xp3.biz/update.html
    For 96-97 ECU users (OBD2): Screen changes are now nice and quick, and much improved datalogging speeds for you too.
    For MUT connection users: Modified connection routine (attempts 3 and 4 now use different method of connecting).
    For users with enhanced OBD2/MUT cables: If disconnected from ECU, the reconnection routine will now take advantage of the new enhanced OBD2/MUT cables by simulating a physical cable removal and reinsertion.
  5. #875
    What cable did you send with mine?
  6. #876
    The new enhanced OBD2/MUT cable came out about 2 months ago, so if it was purchased within that time, then that's the kind you have.
  7. #877
    That I did received it last week, so only the Firmware 3.03 is what I need to down load and flash then?
  8. #878
    Yes that is correct.
  9. #879
    If I did that wouldn't I love the ability to tap my wideband into the lcd?
    EDIT: NVM, I read that the blue wire is only for the WB02 and the white wire is the one I can ground
  10. #880
    Can this flash be done with the devise un-installed?
